mat2495 Posted May 14, 2020 Share Posted May 14, 2020 Hi all, I'm looking for a drivers side locking catch for the rear window on my 1983 110 Hi-Cap. I have tried AEU2805 and AEU2806, one of which fitted the passenger side, and one of which fitted neither side properly. The only parts book I have access to is 1987 onwards, and it is suggesting that my next attempt should be MWC7625 or MWC7648. Firstly, does anyone know if that is right? they are more expensive than the other ones, so I am a bit reluctant to just try it. Also, they are listed as LH and RH, can somebody confirm which way they are looking at the assembly? I don't want to end up with another passenger side one! Thanks Quote Link to comment Share on other sites More sharing options...
western Posted May 14, 2020 Share Posted May 14, 2020 (edited) I'll have a look in my upto 1986 parts book will photo the relevant page Edited May 14, 2020 by western Quote Link to comment Share on other sites More sharing options...
western Posted May 14, 2020 Share Posted May 14, 2020 both panes slide, according to the list on page below, it says sliding glass x 2, so need catches to lock in open or closed positions Quote Link to comment Share on other sites More sharing options...
mat2495 Posted May 16, 2020 Author Share Posted May 16, 2020 Thanks Western. It looks like the part number I have were right then, I will have to dig them back out and have another go, maybe I missed something. I suppose I might have put the glass back in the wrong runner or something while I had it all apart. The problem I was having was that the locking pin wasn't in line with the slots front to back. Quote Link to comment Share on other sites More sharing options...
western Posted May 16, 2020 Share Posted May 16, 2020 the diagram gives the same part number for both panes of glass so swapping them over shouldn't create any problem. not sure if puttig them ineither runner would cause that problem it doesn't say inner/outer or left/right. Quote Link to comment Share on other sites More sharing options...
mat2495 Posted May 17, 2020 Author Share Posted May 17, 2020 (edited) Got it sorted this afternoon, there is an insert in the rail that was slightly out of position, so the slots didn't line up properly. With that sorted and a little trim to the catch pin it is now working a treat. thanks again. Edited May 17, 2020 by mat2495 Quote Link to comment Share on other sites More sharing options...
western Posted May 17, 2020 Share Posted May 17, 2020 Glad you found the fault & it was a easy fix. Quote Link to comment Share on other sites More sharing options...
