kevin50 Posted May 15, 2020 Share Posted May 15, 2020 Here we go again. Waiting on bits to finish Dash so might aswell start on this. I have my Bottle fitted on right hand side due to my 300tdi conversion. It has 2 motors fitted. First and second pic pic is the front windscreen Tube from Bulkhead, Ive turned it to the right side but only way to get it down through Bulkhead in to engine bay was to thread it through that hole in the metal dash panel, Will that be OK ? Will join it to reach the bottle. Next Rear Tube, it is fitted at rear door and reaches to front corner of Drivers door in third pic, will have to join it there and route down somewhere out to engine bay then along to bottle. Quote Link to comment Share on other sites More sharing options...
western Posted May 15, 2020 Share Posted May 15, 2020 Yes should be ok, you can get more tubing & connectors from any motor factors or Halfords, a non return valve in each line would give the pumps a easier time & get almost instant wiper fluid to each screen. for the rearscren tube route in down the screen pillar & through one of the bulkhead grommets to wash tank Quote Link to comment Share on other sites More sharing options...
kevin50 Posted May 15, 2020 Author Share Posted May 15, 2020 31 minutes ago, western said: Yes should be ok, you can get more tubing & connectors from any motor factors or Halfords, a non return valve in each line would give the pumps a easier time & get almost instant wiper fluid to each screen. for the rearscren tube route in down the screen pillar & through one of the bulkhead grommets to wash tank Thanks Mate, Got one of these today, they only had one in will get another later, which way does it go or does it not make any difference, as one end is wider. ?? Quote Link to comment Share on other sites More sharing options...
oneandtwo Posted May 15, 2020 Share Posted May 15, 2020 It’s a non return valve it goes in the direction of the arrow! Quote Link to comment Share on other sites More sharing options...
kevin50 Posted May 15, 2020 Author Share Posted May 15, 2020 12 minutes ago, oneandtwo said: It’s a non return valve it goes in the direction of the arrow! Cheers Mate just noticed the Arrow 1 Quote Link to comment Share on other sites More sharing options...
