Harry m Posted May 16, 2020 Share Posted May 16, 2020 I have put the 90 200tdi back on the road after spending a few years sorting it out it’s amazing how one job leads to another. it now running ok and back using it but every now and again the clutch pedal stays down pull it back up and everything is ok, im thinking it could be the slave cylinder may need bleeding or changing ? Or could it be something else Quote Link to comment Share on other sites More sharing options...
92a Posted May 16, 2020 Share Posted May 16, 2020 Try lubricating the pivot points and shaft (take the top off the turret under the bonnet to get lubricant in the right place ) and protect any carpet you may have from drips Quote Link to comment Share on other sites More sharing options...
neil110 Posted May 16, 2020 Share Posted May 16, 2020 I had something similar with mine and it turned out to be the slave cylinder pipe sitting too close to the exhaust pipe and getting 'kin hot Quote Link to comment Share on other sites More sharing options...
