Battery charge gauge
Wire the live terminal to one of the plain white ignition switched wires & other terminal to earth, gauge lighting to existing gauge lighting.that way the Batt gauge will shut down when ignition is off.
If you want a gauge with a better display the 52mm VDO Vision voltmeters are good. https://www.vdo-gauges.com/vision-black-12v-voltmeter.html
