LR90 Posted May 24, 2020 Share Posted May 24, 2020 Wow been a while! Stuck at home and looking to refresh the springs and shocks. I used spring isolators at the front last time but can’t find the part number I ordered. RBC100111 looks similar but is for a Disco II, will these fit my 90? https://www.ebay.co.uk/itm/Front-Upper-Coil-Spring-Isolator-Turret-Rings-for-Land-Rover-Discovery-2-/292389210046 TIA Trev Quote Link to comment Share on other sites More sharing options...
western Posted May 24, 2020 Share Posted May 24, 2020 Hiya Trev, Don't know if the D2 items will fit but this is the Discovery 1 & RR spring isolators which will fit straight on.https://www.brit-car.co.uk/product.php/82070/0/isolator_upper_rear_springs_discovery_1___2___range_rover_classic Quote Link to comment Share on other sites More sharing options...
Eightpot Posted May 24, 2020 Share Posted May 24, 2020 ANR2938 is the disco 1 style Quote Link to comment Share on other sites More sharing options...
LR90 Posted May 24, 2020 Author Share Posted May 24, 2020 Magic, thanks guys 😊 1 Quote Link to comment Share on other sites More sharing options...
Lightning Posted May 24, 2020 Share Posted May 24, 2020 I fitted Discovery 2 spring isolators in the front of my Defender 110 TD5 Quote Link to comment Share on other sites More sharing options...
Litch Posted May 25, 2020 Share Posted May 25, 2020 I am currently fitting a new chassis to my 90 and fitted ANR2938 to all four springs only yesterday. 😁 1 Quote Link to comment Share on other sites More sharing options...
Snagger Posted May 25, 2020 Share Posted May 25, 2020 9 minutes ago, Litch said: I am currently fitting a new chassis to my 90 and fitted ANR2938 to all four springs only yesterday. 😁 Do they fit correctly? I don’t know if the front and rear spring seats are exactly the same size, it I want to do the same on my RRC, which I think only has them in the rear. Quote Link to comment Share on other sites More sharing options...
oneandtwo Posted May 25, 2020 Share Posted May 25, 2020 Rbc100111 fit fine on defender front. 1 Quote Link to comment Share on other sites More sharing options...
hurbie Posted May 25, 2020 Share Posted May 25, 2020 can someone explain to me what these "isolators" do for your springs ? Quote Link to comment Share on other sites More sharing options...
Ex Member Posted May 25, 2020 Share Posted May 25, 2020 14 minutes ago, hurbie said: can someone explain to me what these "isolators" do for your springs ? Give a small lift and reduce noise transfer from the axles. 1 Quote Link to comment Share on other sites More sharing options...
Litch Posted May 25, 2020 Share Posted May 25, 2020 13 hours ago, Snagger said: Do they fit correctly? I don’t know if the front and rear spring seats are exactly the same size, it I want to do the same on my RRC, which I think only has them in the rear. Yes, they fitted fine. No real reason for fitting them, I wasn't after a lift or anything but thought that they can't do any harm and they may prevent noises that I didn't even know were present! Quote Link to comment Share on other sites More sharing options...
Snagger Posted May 26, 2020 Share Posted May 26, 2020 The principle purpose is noise reduction. They stop a lot of the twanging noise from the springs being transmitted to the chassis and body. The lift is small and incidental. Quote Link to comment Share on other sites More sharing options...
