Louie872 Posted May 30, 2020 Share Posted May 30, 2020 Hello fellow Landy enthusiasts; I have an issue which has raised its head recently. My engine electrical warning light came on whilst driving the other day. I have inspected all of the earthing points that I can find (Clutch, chassi near gearbox flexi mount, starter connections, alternator output voltage (reads 14.62V), all the hamfisted wiring which was behind the fuse cover in front of cubby box, connections under both driver and passenger seat.......) I'm at a loss...!!! The engine is still running, any ****ty spade connections have been replaced with sealed solder heat shrink joints to provide better connections for a much longer life. I have also been through the haynes and workshop manual - T**s on a fish...! I need help from some of you legends out there who know how to keep these lovable money pits on the road. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted May 30, 2020 Share Posted May 30, 2020 It might be helpful to say what engine it is 🙂 Mo 1 Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted May 30, 2020 Share Posted May 30, 2020 So which one is the "red engine electrical warning light" - is it the battery symbol? If so that can pretty much only be the alternator or its wiring, you can have a dodgy diode in the alternator and it will still charge but it might also decide to catch on fire depending on the failure. 1 Quote Link to comment Share on other sites More sharing options...
Louie872 Posted May 31, 2020 Author Share Posted May 31, 2020 Hi Mo/Fridge, Sorry for missing out the obvious: Its the TD5. Here's a picture of the light, It came on the other day while I was driving. I can't identify any system so far which has been affected by this. I have tested the Alternator output and this is fine. Quote Link to comment Share on other sites More sharing options...
western Posted May 31, 2020 Share Posted May 31, 2020 IIRC that indicates a immobiliser fault. 1 Quote Link to comment Share on other sites More sharing options...
dailysleaze Posted June 1, 2020 Share Posted June 1, 2020 Try changing the key fob battery based on the instructions in the handbook 1 Quote Link to comment Share on other sites More sharing options...
Jut Posted June 16, 2020 Share Posted June 16, 2020 immobiliser warning light, Quote Link to comment Share on other sites More sharing options...
jim4244 Posted September 23, 2023 Share Posted September 23, 2023 Hi Louie I know that this thread is 3 years old but did you ever get to the bottom of why the immobiliser light was on? Did you ever manage to fix it? Jim Quote Link to comment Share on other sites More sharing options...
