Chambo110 Posted May 30, 2020 Share Posted May 30, 2020 Guys after the above.. but retroanaconda appears to show 2 different types.. or are they actually different things I’m looking at is part 1 and part 3 a 2 piece version of part 9 if that makes sense 1987 110 csw thanks Quote Link to comment Share on other sites More sharing options...
western Posted May 30, 2020 Share Posted May 30, 2020 Later models have the capping in one piece, check the last 8 digits of your chassis number & see which range on that page it falls, you can use 1 piece capping on early vehicles. Quote Link to comment Share on other sites More sharing options...
Chambo110 Posted May 30, 2020 Author Share Posted May 30, 2020 Roger that thanks Ralph Quote Link to comment Share on other sites More sharing options...
oneandtwo Posted May 30, 2020 Share Posted May 30, 2020 There are actually three versions, the original three part version, the later one piece welded version, and the very late Td5 / Puma one piece version. These last version are all one piece pressed construction, eliminating the visible weld beads and reducing the potential rot spots. 1 Quote Link to comment Share on other sites More sharing options...
Chambo110 Posted May 31, 2020 Author Share Posted May 31, 2020 Deffo won’t be the late td5/ puma version as mines an ‘87 Appreciate the info 👍 Quote Link to comment Share on other sites More sharing options...
oneandtwo Posted May 31, 2020 Share Posted May 31, 2020 4 hours ago, Chambo110 said: Deffo won’t be the late td5/ puma version as mines an ‘87 Appreciate the info 👍 Obviously. But if you are replacing them the Puma ones are the best Quote Link to comment Share on other sites More sharing options...
neil110 Posted May 31, 2020 Share Posted May 31, 2020 15 minutes ago, oneandtwo said: Obviously. But if you are replacing them the Puma ones are the best Nah, if you are replacing them the early galvanised ones are far superior Quote Link to comment Share on other sites More sharing options...
oneandtwo Posted June 1, 2020 Share Posted June 1, 2020 16 hours ago, neil110 said: Nah, if you are replacing them the early galvanised ones are far superior Not if you get the Puma ones galvanised they aren’t Quote Link to comment Share on other sites More sharing options...
