jamesledingham Posted January 8, 2007 Share Posted January 8, 2007 I saw in this month's LROI that the chap showing the green lanes on the Wirral had a bed in the back of his 90. Has anyone done this? How easy was it to fabricate? Quote Link to comment Share on other sites More sharing options...
Andy Posted January 8, 2007 Share Posted January 8, 2007 was he a dwarf? i cant imagine how there would be room. mate used to have a bed in the back of a 110 & that wasnt quite long enough to lay flat on, unless you used the bulkhead as a pillow. Quote Link to comment Share on other sites More sharing options...
jamesledingham Posted January 8, 2007 Author Share Posted January 8, 2007 was he a dwarf? i cant imagine how there would be room. mate used to have a bed in the back of a 110 & that wasnt quite long enough to lay flat on, unless you used the bulkhead as a pillow. Comfy! That was the bit that confused me. Either he's a midget, or anyone who wants to use the passenger seat has to be. It looked to be more than just removing the headrest didn't it! Quote Link to comment Share on other sites More sharing options...
siearl Posted January 8, 2007 Share Posted January 8, 2007 Have thought about it with the 110 but then as you say dont think it would be big enough and certain a 90 would be very crampted Quote Link to comment Share on other sites More sharing options...
Mark90 Posted January 8, 2007 Share Posted January 8, 2007 I had a 6'2" by 4' bed in the back of my 110 CSW. Two bits of 12mm ply 4' wide, one 4' long the other 2'2". Long board placed over back of middle row seats with backs folded forward, bottom of this boad sat on a bit of 2"x4" that rested across the rear bench seats (cushions removed) to make it level. The smaller board rested on this bit of 2"x4" also and the other end on another bit of 2"x4" aross the back just by the rear door. The smaller section at the back was easily lifted to access storage under the bed, rear footwell accessible through rear side doors provided extra storage space too. If you where a bit taller and needed a longer bed a few more inches is easily possible especially if the fronts seats where tipped forward. In a 90 a reasonable sized bed can be constructed at bulkhead height stretching from the rear door to the dash going over the fronts seats which are tipped forward. Quote Link to comment Share on other sites More sharing options...
nige90 Posted January 9, 2007 Share Posted January 9, 2007 I removed the bulkhead and centre seat on the 90 and can easily sleep in it with feet between the seats. When I had the 88" S3 I made a tent affair that fitted over the drop down tail gate and two could sleep in there. Had to be good friends though Coincidently I'm on the Wirral too ! Quote Link to comment Share on other sites More sharing options...
edwardatherton Posted January 9, 2007 Share Posted January 9, 2007 I travelled in Paul's 'bedroom' a couple of weekends ago on a green-lane trip when the S1 didn't want to run. There are two pieces of board which go from the rear door to the dash, and a couple of pieces of foam that go on top. That's it. Nice and simple! Quote Link to comment Share on other sites More sharing options...
jamesledingham Posted January 9, 2007 Author Share Posted January 9, 2007 I travelled in Paul's 'bedroom' a couple of weekends ago on a green-lane trip when the S1 didn't want to run.There are two pieces of board which go from the rear door to the dash, and a couple of pieces of foam that go on top. That's it. Nice and simple! Where's it all stored when it's not in use? Any chance of some pics? (not of you in bed, but of the bed itself!!) Quote Link to comment Share on other sites More sharing options...
edwardatherton Posted January 9, 2007 Share Posted January 9, 2007 Where's it all stored when it's not in use?Any chance of some pics? (not of you in bed, but of the bed itself!!) Simply stood on their side in the box he has built over the wheelarch. The box holds all the recovery gear, and then a couple of straps/clips hold the stuff upright. Quote Link to comment Share on other sites More sharing options...
SiWhite Posted January 9, 2007 Share Posted January 9, 2007 Any chance of some pics? Quote Link to comment Share on other sites More sharing options...
jamesledingham Posted January 9, 2007 Author Share Posted January 9, 2007 Any chance of some pics? Hi, where are you based? You're obviously looking to make a bed in your 90 too! James Quote Link to comment Share on other sites More sharing options...
edwardatherton Posted January 10, 2007 Share Posted January 10, 2007 I don't have any pictures, but I'm pretty sure Paul's email address is in the LRO article. Quote Link to comment Share on other sites More sharing options...
SiWhite Posted January 10, 2007 Share Posted January 10, 2007 Hi,where are you based? You're obviously looking to make a bed in your 90 too! James James, Mostly in Wantage, SW of Oxford. Si Quote Link to comment Share on other sites More sharing options...
