Vent ABS System
WesBrooks
I should have made it clear I am stripping the system for transplant into a new build.
Thinking about the valves I will just drain the tank, then disassemble from the highest point down just sucking out the fluid as it becomes exposed. Will get some spill, but shouldn't be too bad.
Are there any off the shelf plugs for the flares when removed to stop junk getting in the system? Seem to remember a M10 * 1mm thread being mentioned someplace. Other option woul be just to cut the pipes, fold and re-tighten flares. Bound to scratch myself on the hedgehog that will be the valve block though! 😄
