Leigh831 Posted June 1, 2020 Share Posted June 1, 2020 Hi - Ive got a 2.7 Sport 07 plate, I took out the troublesome suspension and put in shocks and coil springs but my rear suspension is over 2" lower than the front and with 3 people in going up a hill on a dirt track it drags catching the exhaust all the way up the track Ive measured the exhaust to the floor and its not even 4 " measurements from the centre of the wheel to the wheel arch on the front is 18" and 19" and at the back its 16" and and 17" Looking for some ideas as to why this may be and what to try to sort it out Thanks Leigh Quote Link to comment Share on other sites More sharing options...
geoffbeaumont Posted June 2, 2020 Share Posted June 2, 2020 What did you fit in place of the air springs? Sounds like the coils you fitted are far too weak. Is be concerned about handling on the road as well as ground clearance - it doesn't sound terribly safe! What problem were you having with the EAS? Quote Link to comment Share on other sites More sharing options...
Leigh831 Posted June 2, 2020 Author Share Posted June 2, 2020 9 hours ago, geoffbeaumont said: What did you fit in place of the air springs? Sounds like the coils you fitted are far too weak. Is be concerned about handling on the road as well as ground clearance - it doesn't sound terribly safe! What problem were you having with the EAS? i fitted springs and coils and the electric box to take the lights off the dash. Brought them off Ebay and they posted me 4 x 13mm rubber spacers to fit. to see if this would work Took it to a gagrge who said they think springs are too weak just wanted some more advice before i tackle the seller Quote Link to comment Share on other sites More sharing options...
