Windscreen frame
fearofweapons
After a bit of advice. Doing up the wife's SIII and the windscreen frame has been painted. Removing the paint has damaged the galv. Having had a quick look around it would seem you can no longer buy new wind screen frames. Or can someone prove me wrong please?
So as a fall back looking to get it blasted and galvanised. Can anyone recommend a blasters and galvanisers in the Leeds / Bradford / West Yorkshire area please?
regards,
Richard.
Sorry, no - but.... when you put the glass back in, if used as more than a summertime plaything, shove heated-screens in.  Worth every penny on those dampish Autumn days when the demister won't clear the condensation, and in Feb... should be a legal requirement.
Edited by Landrover17H
There was one on the Hessle road in Hull when I went past a little while ago now. Have a look on Street view for it. It's on the left as you go towards the dock, after the swing bridge and just before a roundabout.
Edit: couldn't resist and did it for you
https://www.wedge-galv.co.uk/plant-locator/humber-galvanizing-ltd/
but they have a plant nearer to you
https://www.wedge-galv.co.uk/plant-locator/metaltreat-galvanizers/
Edited by Peaklander
Two suppliers:
Urgoglass via Devon 4x4.
I've these. Not amazing quality, to be honest, the silver strips at top and bottom of the screens are visible after fitting, and I can see some bubbles in the laminated part.
Plus the glass feels a little small for the frame, I used a tube of sealant around them to get them snug.
And Ricky Evans.
I've no experience with these, but am going to try them on the lightweight.
They might be worse!
