andy _1 Posted June 6, 2020 Share Posted June 6, 2020 I am full of problems this week doing all the jobs I should have done but any way , the oil light has never worked I have checked the bulb and continuity all the way from the switch to the bulb all ok . So anyone have any idea . The brown and white is a earth I assume so where the live coming from? Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted June 8, 2020 Share Posted June 8, 2020 The live goes to the bulb, bulb to switch. If you touch the wire terminal off the sender to a clean bit of the engine block the light should come on. If so, the sender unit is duff. Quote Link to comment Share on other sites More sharing options...
western Posted June 8, 2020 Share Posted June 8, 2020 the sender is earthed via the engine block, the sender wire should be 12v live, as above most likely a dead sender unit. Quote Link to comment Share on other sites More sharing options...
Chubby M Posted June 9, 2020 Share Posted June 9, 2020 On 6/6/2020 at 5:49 PM, andy _1 said: I am full of problems this week doing all the jobs I should have done but any way , the oil light has never worked I have checked the bulb and continuity all the way from the switch to the bulb all ok . So anyone have any idea . The brown and white is a earth I assume so where the live coming from? Hi Andy, while I can't help with the oil sender, could I ask a favour of you please? I see you have a 2.5td. I'm after a photo of the engine bay where the air-filter canister connects (to the chassis or where ever else...) After a re-chassis and loss of my photos I'm a bit stuck.. any photo much appreciated. Mark, Quote Link to comment Share on other sites More sharing options...
