Plug terminal type ID please (Eberspacher heater)
Had to pull my Eberspacher heater as its been giving error codes, and having tracked down the probable caue tried to obtain the replacement small wiring loom/sensors. However in their infinite wisdom (and without apparently making most dealers aware) Eberspacher at some point 'upgraded' the internal wiring connector plug and I now need to bodge a repair as mines is an older heater model which uses the previous iteration plug. It has these female terminals which I'm currently trying to gently prise apart to remove the old wire so I can maybe reuse them but its not going smoothly as the metal is really hard. Anyone know what they're called so I can try and track down a half a dozen new ones?
apr20jmp35677.jpg.69189f7771f4801e4d6089f90fb05abe.jpgapr20jmp35679.jpg.b2567a97ac1d4d0355664ac5ecfb5c58.jpgapr20jmp35680.jpg.94320dce6210fbfbded3f7924eb86a37.jpg
