keeley75 Posted June 10, 2020 Share Posted June 10, 2020 Does anyone know what specification and size the pipe fittings are that go into the engine oil cooler fitted in the side of the Disco 1 V8 radiator. These are also the same fitting as used on the bog brush style gearbox oil cooler. Im looking for new ends that will either adapt to AN fitting or fit to dedicated oil pipe. Thanks in advance Quote Link to comment Share on other sites More sharing options...
keeley75 Posted June 12, 2020 Author Share Posted June 12, 2020 From Allisport the threads are M20x1.5mm What I'd like to know is what the fitting is called... Quote Link to comment Share on other sites More sharing options...
neil110 Posted June 12, 2020 Share Posted June 12, 2020 (edited) your best bet might be to take them to your local branch of Pirtek. I have always found them to very knowledgeable and helpful https://www.pirtek.co.uk Edited June 12, 2020 by neil110 Quote Link to comment Share on other sites More sharing options...
keeley75 Posted June 13, 2020 Author Share Posted June 13, 2020 Right so the process is called Tube Forming. There are a few companies in the UK that do it. You can get pipes made up in Stainless Steel. Land Rover pipework is expensive and not always available. I'm thinking of having short Stainless steel pipes made up with unions to convert it straight to easily available AN fittings as used in kit car and race car stuff. Quote Link to comment Share on other sites More sharing options...
