steve200TDi Posted June 16, 2020 Share Posted June 16, 2020 Hi, I've found an Art Carr shift on ebay and so I'm doing my research into aftermarket shifters. From the review videos I've seen, they are simple in construction and built for off road use. What I'm wanting to find are photos of an install, the cables, the brackets. I think its just a question of designing a bracket for the gearbox that gives the right throw so that it lines up with the shift points of the shifter. The next question is, is a 6 point shift the same as a 7 point shifter? As I've found this on ebay: https://www.ebay.co.uk/itm/Land-Rover-kit-Car-Arttcar-Gear-Shifter/283913621895?hash=item421a921187:g:DBEAAOSwZCBd840o It only has P, N, R, 3, 2, 1 and I need a D or 4. If its just a case of making a new gate up with 7 positions then I'm willing to have a play and see if I can get it to work. I may have to buy a cable, so that will be another thing to sort too! Steve Quote Link to comment Share on other sites More sharing options...
ashtrans Posted June 25, 2020 Share Posted June 25, 2020 Yes you would need to make a new gate plate to match the ZF detent positions, easier said than done to get right in my experience Quote Link to comment Share on other sites More sharing options...
steve200TDi Posted December 6, 2020 Author Share Posted December 6, 2020 I did end up buying this shifter. You can follow my progress here: Quote Link to comment Share on other sites More sharing options...
