murrayonshore Posted June 21, 2020 Share Posted June 21, 2020 Hi folks, I am not a mechanic, but bought a 2003 Land Rover Discovery Se for some remote camping, but - avoiding all the background - quarantine and lock down fate prevented me from getting maintenance and it was driven by a family member resulting in an engine failure. It had sat unused for 3 months and I ironically had come back to pick it up, do maintenance etc. I was not the driver so can't speak first hand, but it seemed there was a strange noise (tapping or clicking) while driving then the engine died. That's when the white steam (and possibly smoke, drying coolant?) was spotted billowing out the sides. The temperature gauge was low the whole time. When I arrived on the scene an hour later, things had cooled, and I found the oil OK, but coolant was empty. I added 3L of water and after it circulated each time it would hiss and steam up at the thermostat housing. The engine turned with the ignition, but would not engage at all. It sounds like there is spark, but no ignition. I got a tow. Now parked up waiting for a mechanic to take a look Monday. 1. Manual Mode and Sport Mode are both flashing = bad. 2. Check Engine is illuminated = bad. 3. Low Oil Pressure illuminated = bad. 4. Temp overheat light illuminated = bad. I'd like to ask those of you who may know whether you have some idea of what the cause might be - based on probabilities. I'll come back once I have a professional look at it, but my concern is that I am at the mercy of the mechanic who could easy fleece me (the Noob!) on this. Thanks in advance!! Quote Link to comment Share on other sites More sharing options...
Simon_CSK Posted June 21, 2020 Share Posted June 21, 2020 Wlecome to the forum You don't say what model D1,2,3 or 4 or what engine Diesel or V8 Petrol. My guess from the photos it is a D2 V8 petrol. In which case then there is a very good chance the the engine is cooked. First thing I would do is have it confirmed that the head gasket is blown, a common problem with Rover V8's. Once armed with that confirmation I would try block sealer. for £20 it may or may not work. Failing all that you are looking at a head gasket replacement. But get a proper diagnosis first. Quote Link to comment Share on other sites More sharing options...
murrayonshore Posted June 22, 2020 Author Share Posted June 22, 2020 7 hours ago, Simon_CSK said: Wlecome to the forum You don't say what model D1,2,3 or 4 or what engine Diesel or V8 Petrol. My guess from the photos it is a D2 V8 petrol. In which case then there is a very good chance the the engine is cooked. Simon_CSK thank you very much. Yes, I believe it is a D2, and yes it is petrol V8. your advice seems bang on. Going down to the shop today for a diagnosis. I shall report back! Quote Link to comment Share on other sites More sharing options...
