Sharp Posted June 21, 2020 Share Posted June 21, 2020 I need to replace my calipers and would like some help finidng the right part number. I plan to rebuild the ones I have but need a cheap pair to see me until I have time to do it. I'm a bit confused on what to get. The vehicle is a 1998 300tdi 110 county, vin number WA147XXX. Discs are vented and the retainers are the spring type not the flat plate. The current calipers are Lockheed, I think the codes are LB10TY017AC and LB10TY018AC but I noticed from another thread that someone had the same code on their calipers and had non-vented discs. In any regard I want to refurb the ones I have so really just need to get hold of some cheap ones to get me back on the road. When I put my vin number into the LRWorkshop website it lists 7 different part numbers (listed below). The last two in the list are £36 each, does anyone know if these will fit? (RTC4998 and RTC4999). Any help much appreciated LR017738 Without lining, LH, Caliper assembly-front brake LR017742 Without lining, RH, Caliper assembly-front brake LR017748 Without lining, RH, Caliper assembly-front brake LR017752 Without lining, LH, Caliper assembly-front brake RTC3380 Without lining, RH, Caliper assembly-front brake RTC3381 Without lining, LH, Caliper assembly-front brake RTC4998 Without lining, RH, Caliper assembly-front brake RTC4999 Without lining, LH, Caliper assembly-front brake Pictures of the calipers that are on just now: Quote Link to comment Share on other sites More sharing options...
western Posted June 21, 2020 Share Posted June 21, 2020 I bought a pair recently I'll add the part numbers of them shortly. Right front vented caliper SEB500460 Left front vented caliper SEB500470 About 60 quid each plus VAT. On both of these the outer faces lower edge fouled the inner face of the hub, a bit of grinder action on both created some clearance. Quote Link to comment Share on other sites More sharing options...
Sharp Posted June 21, 2020 Author Share Posted June 21, 2020 That's great Western, thanks for your help 1 Quote Link to comment Share on other sites More sharing options...
Will@LRW Posted July 5, 2020 Share Posted July 5, 2020 Your post brought my attention to some parts that would be listed as false positive applications if the part is based on an axle range. This should be fixed now and would have removed a few options from the list you gave above. Cheers Will Quote Link to comment Share on other sites More sharing options...
