isbjorn Posted June 24, 2020 Share Posted June 24, 2020 Hello. I think I once had a PDF from landrover about rust proofing the Defender. Where to spray to reach all cavities and so on... Not sure I'm remembering correctly, but a bit like the water ingress manual but for spraying vax, dinitrol, oil or whatever your favorit method is. (I vote Linseed oil). Am I correct, or is it just something I dreamt? Cant find any traces from it on the web anyway... thanks. Quote Link to comment Share on other sites More sharing options...
isbjorn Posted June 24, 2020 Author Share Posted June 24, 2020 And how do you actually go about rustproofing the inside of the bulkhead. So far I've found: Remove the top hinge bult and spray in the hole using a pipe and a 360 head.. Use the holes next to the wipers (that is covered with small round rubber bits) and spray spray spray... Quote Link to comment Share on other sites More sharing options...
Lightning Posted June 24, 2020 Share Posted June 24, 2020 (edited) If you take out the interior light switch you can use a 60cm extension tube on an aerosol wax product through the hole. I managed to get the tube right up to the windscreen blocks as the spray grease could be seen to seep out of the seams. You can then just move the tube around while spraying the product. Edited June 24, 2020 by Lightning Quote Link to comment Share on other sites More sharing options...
mickeyw Posted June 24, 2020 Share Posted June 24, 2020 I'm not sure I e ever seen a manual as such, but I have a recollection that I may have read something like it as part of a body panel repair/replacement instruction sheet. Quote Link to comment Share on other sites More sharing options...
L19MUD Posted June 25, 2020 Share Posted June 25, 2020 I think the PDF manual you are thinking of is the water ingress manual Quote Link to comment Share on other sites More sharing options...
western Posted June 25, 2020 Share Posted June 25, 2020 Got these pages in this booklet 1 Quote Link to comment Share on other sites More sharing options...
