Bigj66 Posted June 25, 2020 Share Posted June 25, 2020 Does anyone know of a company that will modify existing half shafts? By that I mean shorten them and reground the splines? My local engineering company is swamped with back orders and have told me it will be at least 8 weeks before they could look at doing the work for me. I would like to get the chassis on wheels again as soon as I can so I can move it about to finish the rest of the work on it as lifting a ZF box onto the back of a V8 by hand isn’t good for my back 🚑 Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted June 25, 2020 Share Posted June 25, 2020 Rakeway might do it but they're not renowned for speedy turnaround... 1 1 Quote Link to comment Share on other sites More sharing options...
Gazzar Posted June 25, 2020 Share Posted June 25, 2020 Try Albany pumps in the forest of Dean. They do oil and gas work, which is light at the moment, apparently. It should be the same sort of engineering splines and stuff. I've no association with them, I just pass their place when I'm out and about. Quote Link to comment Share on other sites More sharing options...
Bigj66 Posted June 25, 2020 Author Share Posted June 25, 2020 4 minutes ago, Gazzar said: Try Albany pumps in the forest of Dean. They do oil and gas work, which is light at the moment, apparently. It should be the same sort of engineering splines and stuff. I've no association with them, I just pass their place when I'm out and about. Nearly as light as offshore wind farms...🤨 Will look them up 👍 Quote Link to comment Share on other sites More sharing options...
Jon White Posted June 26, 2020 Share Posted June 26, 2020 Wisbech Engineering can do it. Top quality engineers they have a fantastic reputation 👍🏻 1 Quote Link to comment Share on other sites More sharing options...
landroversforever Posted June 26, 2020 Share Posted June 26, 2020 Which shafts are they? A lot of them aren't the same diameter as the spline the whole length. 1 Quote Link to comment Share on other sites More sharing options...
bishbosh Posted June 26, 2020 Share Posted June 26, 2020 Just to note you can get it back on its wheels without the half shafts 1 Quote Link to comment Share on other sites More sharing options...
Bigj66 Posted June 26, 2020 Author Share Posted June 26, 2020 I may have another solution that involves cutting the shaft to reduce the length in the centre and then joining the two halves together using friction welding. That would avoid the need for any grinding of the splines and interference with the hardening. Cheaper than new shafts too but there’s limitations and more to investigate about the process so will see what happens. Quote Link to comment Share on other sites More sharing options...
Bigj66 Posted June 26, 2020 Author Share Posted June 26, 2020 5 hours ago, bishbosh said: Just to note you can get it back on its wheels without the half shafts Problem is that I’m at a halfway stage and have already stripped out the bearings etc from the series hubs so I can’t bung them back on and, without the adapters I can’t get the new hubs on so it’s just a case of waiting until the adapters are made. Quote Link to comment Share on other sites More sharing options...
Ed Poore Posted June 26, 2020 Share Posted June 26, 2020 I've got a friend () down here who I suspect would probably be able to do it and knowing him for not a lot. He's popping over on Sunday to look at some work for me so if I remember I can ask the question. Certainly got the tools to do it - he skimmed the head of my sister's Td5 in a single pass on one of his smaller mills . 1 Quote Link to comment Share on other sites More sharing options...
