1981 Stage 1 wings to a 90
Unfortunately not as they are a different design.
The Series wings have a rear section whereas the 90 wings have no rear but instead join up to the steel inner wing, also the cutout is larger to allow for the flexible eyebrow.
The truck-cab will not fit the 90 windscreen as the later screen is taller, the only way to do this is to fit the Series windscreen as well (they are the same width).
  • Like 1
7 hours ago, Cchase said:
Will the fenders (wings) and pick up cab from a 1981 V8 fit a 1984 90?
Thanks
Out of interest, what’s the story with the Stage 1? Is it being broken for some reason or do you just have a set of wings lying about that you want to use? There’s not many Stage 1s about and I would imagine even less in your neck of the woods.
Thanks. For the info.
I have a 90 parts truck which might be good enough to rebuild. Looking at options.
 Share
