steve200TDi Posted July 17, 2020 Share Posted July 17, 2020 Here's is another sketch of the windscreen seal as a cut through. Hope this helps Steve Quote Link to comment Share on other sites More sharing options...
miketomcat Posted July 17, 2020 Share Posted July 17, 2020 (edited) Sorry I forgot the flap that tucks into the screen frame. Mike Edited July 17, 2020 by miketomcat Quote Link to comment Share on other sites More sharing options...
kevin50 Posted July 17, 2020 Author Share Posted July 17, 2020 (edited) 1 hour ago, steve200TDi said: Thanks gonna have another look tonight. will take pics Edited July 17, 2020 by kevin50 Quote Link to comment Share on other sites More sharing options...
ThreePointFive Posted July 17, 2020 Share Posted July 17, 2020 I am just about to do this myself, my frame is off the car so thought it would be easier to get access. Starting to wonder if I shouldn't just get someone else to do it, a quick google revealed a mobile fitter with a fairly good reputation just a few streets away but he's left out the "how much" aspect of his response.... Quote Link to comment Share on other sites More sharing options...
kevin50 Posted July 17, 2020 Author Share Posted July 17, 2020 1 hour ago, ThreePointFive said: I am just about to do this myself, my frame is off the car so thought it would be easier to get access. Starting to wonder if I shouldn't just get someone else to do it, a quick google revealed a mobile fitter with a fairly good reputation just a few streets away but he's left out the "how much" aspect of his response.... Wished I lived a few streets from you, think I would get him to do it. Quote Link to comment Share on other sites More sharing options...
kevin50 Posted July 17, 2020 Author Share Posted July 17, 2020 (edited) Right still cant get jhow the screen fits in to the Rubber First before it is placed on to car. Took these pics, The only 2 slots I can see on one side in first pic, where I think the screen should go, the one i have a hold of is deeper and flat , the other has curve on it, other side just has grooves , but dont hold the glass in place. Edited July 17, 2020 by kevin50 Quote Link to comment Share on other sites More sharing options...
HampshireHog Posted July 18, 2020 Share Posted July 18, 2020 19 hours ago, ThreePointFive said: I am just about to do this myself, my frame is off the car so thought it would be easier to get access. Starting to wonder if I shouldn't just get someone else to do it, a quick google revealed a mobile fitter with a fairly good reputation just a few streets away but he's left out the "how much" aspect of his response.... Just what I thought but the fitters that eventually did mine said it was more of a pain in the ar** out of the vehicle Quote Link to comment Share on other sites More sharing options...
ThreePointFive Posted July 18, 2020 Share Posted July 18, 2020 9 hours ago, HampshireHog said: Just what I thought but the fitters that eventually did mine said it was more of a pain in the ar** out of the vehicle Great... I did think that might be the case as you can't apply pressure from the other side. All the more reason to get a professional to do it I guess. Quote Link to comment Share on other sites More sharing options...
HampshireHog Posted July 19, 2020 Share Posted July 19, 2020 18 hours ago, ThreePointFive said: Great... I did think that might be the case as you can't apply pressure from the other side. All the more reason to get a professional to do it I guess. My thought process went along the lines of , 35 years ago I did a couple of screens in a mini and a cortina I think and they weren’t difficult I hadn’t factored in age , memory being coloured a rosey tint and arthritis . 🤨 Quote Link to comment Share on other sites More sharing options...
steve200TDi Posted July 19, 2020 Share Posted July 19, 2020 The part of the seal you can see from the outside of the vehicle has a small groove contour on it. This should be a datum of how the seal sits/fits. Steve Quote Link to comment Share on other sites More sharing options...
Oakmaster Posted July 21, 2020 Share Posted July 21, 2020 On 7/15/2020 at 8:02 AM, Maverik said: Fitted a few now using the rope method myself, soak the seal in some hot water to soften it up, then using lost of soap, get the seal on the window and start working the rope and seal onto the frame. here's a seconder for the warming it up in a tub of hot water, with fairy liquid as the lubricant (or KY Jelly its been rumored !) I can say that the alpine lights really benefit from the hot water - stops the gaps where they meet end to end. (I learned the hard way) Quote Link to comment Share on other sites More sharing options...
Geojake Posted August 20, 2020 Share Posted August 20, 2020 I am losing my mind. Could someone please explain to me Why there are three lips on these seals? Am I being stupid? I can only get the rubber onto the screen with in one of the lips. But I can’t get my head around the rest. I cut the outer lip of my old rubber to remove the glass so cannot compare. Can anyone verify from the images below if I am on the correct lines? Quote Link to comment Share on other sites More sharing options...
ballcock Posted August 20, 2020 Share Posted August 20, 2020 The rubber face which faces out on the outside has a dimple running along it. The one groove holds the glass another fits over the lip of the frame and the edge with the dimple covers the gap. Quote Link to comment Share on other sites More sharing options...
