mikeyb13 Posted July 25, 2020 Share Posted July 25, 2020 So my edis 8 module has decided to pack up and seen as they are now getting pretty thin on the ground I'm looking at other options. Has anyone used anything other than edis on their builds? Looking for suggestions/advice on what route to take. Thanks Mike Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted July 25, 2020 Share Posted July 25, 2020 VAG coils are the modern way - driven with low-voltage from the ECU, an easy change from EDIS. You'll need the ECU modified and a tweak to your wiring and that's about it. Nige at MSV8 can get it done. Are you sure the EDIS is dead? Very rare to hear of one failing, usually it's wiring or sensor. Quote Link to comment Share on other sites More sharing options...
mikeyb13 Posted July 25, 2020 Author Share Posted July 25, 2020 I have the ms3x so it's all set for low voltage coils. Definitely the edis, sending constant negative signal to the coils. Quote Link to comment Share on other sites More sharing options...
