Door Locks
Can you buy these bits separate, or do you have to buy a full kit. ? cant find any anywhere ? I need the bit that Barrel goes in to with the Orange ring round where it screws in   on this Pic. I have the Handles just need these bits.
Not sure if there is a satisfactory/semi permanent way of holing the rods/levers together,  some welding wire wrapped around the end of the rod & the twisted back to the section of rod above the lever might work.
how come you ran out of those clips they are reuseable unless broken
any of the independent parts suppliers should be able to supply, Brit-car for example https://www.brit-car.co.uk/product.php/412069/5497/clip_linkage_door_latch___defender
1 minute ago, western said:
Not sure if there is a satisfactory/semi permanent way of holing the rods/levers together,  h
Wasnt the fact I run out just only had one I found on an old door, the rest gone missing somwhere , just wanted it done quick really as should be ready for MOT next week.
Will order them if I have to.
3 hours ago, western said:
ah I see, I would get some more & then you know the doors will work correctly, if a door cannot be opened/closed on a MOT that will be a fail.
They can open and close, but they cant lock yet, would it fail on that?
32 minutes ago, western said:
not locking with a key is not in the test, just that the door can open & close & stay closed & not able to fly open when driving,
Thanks, Its getting Tracking done Monday and they are going to give it a check over before the MOT. Im taking it to my local Land Specialist , rather people that know Defenders do it rather then back street garage that dont know much about them. Getting worried now praying Ive done everything right.
