xychix Posted October 16, 2021 Author Share Posted October 16, 2021 2 hours ago, steve b said: Good work , if it works well enough for your use then leave your exhaust as is , you are non turbo anyway so less volume to exit . When do you hope to be finished and tested for road ? Steve did a 5km test today. worked great. Do need the engine to get to temp to do oil flush of al the carp. Therefore I'd need atleast a closing thermostate (now it appears to be stuck open). But other than that I feel road worthy. Lights and stuff are all back working. Before next summer the fan would be nice as an insurance. Quote Link to comment Share on other sites More sharing options...
Nonimouse Posted October 18, 2021 Share Posted October 18, 2021 On 10/16/2021 at 8:32 PM, Gazzar said: I've had mine for over a decade, still don't have a fan, or a decent air filter. I did offer you one Quote Link to comment Share on other sites More sharing options...
Gazzar Posted October 18, 2021 Share Posted October 18, 2021 That's right, circumstances, I think, meant it didn't happen. But next time you are passing, I'd be delighted to take it from you. Quote Link to comment Share on other sites More sharing options...
xychix Posted October 29, 2021 Author Share Posted October 29, 2021 I had my disco thermostat below all the series thermostat housing parts. Ditched that and placed the series thermostat between the top and middel part of the housing. Now all seems better, however I mist have broken a wire doing some electrical jobs as I now have temp meter AND diesel gauge not moving at all Quote Link to comment Share on other sites More sharing options...
Arjan Posted October 29, 2021 Share Posted October 29, 2021 Feed to gauges. Just take a coffee, have a search and enjoy 1 Quote Link to comment Share on other sites More sharing options...
xychix Posted December 31, 2021 Author Share Posted December 31, 2021 it appears my 10v supply unit is nowhere to be found. Will rebuild my own 10v supply. Also the rubber of the front propshaft is rubbing on the sump oil pickup pipe. Might try and fit the propshaft the other way around to avoid this.... Quote Link to comment Share on other sites More sharing options...
