Sophia23 Posted August 4, 2020 Share Posted August 4, 2020 Hi im restoring a a LD2 td5 2001 and there is a massive rott hole behind the drivers side as well as rott inside pillar b im wondering how I could fix this. Thank you. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted August 5, 2020 Share Posted August 5, 2020 The answer is "welding" basically. Quote Link to comment Share on other sites More sharing options...
bishbosh Posted August 5, 2020 Share Posted August 5, 2020 Yep, as Fridge says, cut out the rot (angle grinder or plasma cutter) then weld in repair pieces. Not a job for the feint hearted but definitely doable by a competent DIYer Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted August 5, 2020 Share Posted August 5, 2020 @Shackleton has a lot of good videos on the subject to inspire you: 1 Quote Link to comment Share on other sites More sharing options...
joe1 Posted August 7, 2020 Share Posted August 7, 2020 As above all assuming the rear chassis is actually ok - or has planned work in progress. If the body is bad I cant help think the chassis will be worse.... 1 Quote Link to comment Share on other sites More sharing options...
