300 Tdi into 1989 90
Good evening
Has anybody got what wires are for what where the multi plug connects on the bulkhead for engine loom.  Before I try and find the correct wiring diagram ?   Looks like it had a 19j fitted previously.
thanks in advance
Edited by muddydisco
Same wire colours on both engine looms, in fact you can retain & use the TD engine  loom on the 300Tdi then you won't have to retermnate any bulkhead connectors as the 300tdi use later plastic plugs instead of the rubber cased type.
the glowplug relay can be wired in to work & the alternator connections may need to be changed to suit.
