missingsid Posted August 15, 2020 Share Posted August 15, 2020 LRParts.net are £20 cheaper but their Series version is the same price as the Defender one which is £140 cheaper than Craddock. https://www.lrparts.net/da9017-overdrive-unit-for-land-rover-defender-by-roamerdrive-adds-optional-28-to-ratio-of-drive-train.html Quote Link to comment Share on other sites More sharing options...
mickeyw Posted August 15, 2020 Share Posted August 15, 2020 Isn't that DA9017 reference a Britpart code? If it is I guess that means they are the distributor, and probably supplying most of the UK (and maybe further) market. I would have thought that would mean the price isn't going to vary enormously between vendor. Quote Link to comment Share on other sites More sharing options...
Peaklander Posted August 15, 2020 Share Posted August 15, 2020 Yes I believe that they are now being distributed through Britpart in much the same way that Marsland now do with their chassis sales. Quote Link to comment Share on other sites More sharing options...
Snagger Posted August 16, 2020 Share Posted August 16, 2020 On 8/15/2020 at 4:48 PM, Peaklander said: Yes I believe that they are now being distributed through Britpart in much the same way that Marsland now do with their chassis sales. Britpart is a distributor for them. Quote Link to comment Share on other sites More sharing options...
Anderzander Posted August 16, 2020 Share Posted August 16, 2020 @Maverik Neat job on the bottom row of switches in your console 👍🏻 Quote Link to comment Share on other sites More sharing options...
Peaklander Posted August 16, 2020 Share Posted August 16, 2020 2 hours ago, Snagger said: Britpart is a distributor for them. Isn’t that what I said? Quote Link to comment Share on other sites More sharing options...
Cornish Rattler Posted August 16, 2020 Share Posted August 16, 2020 Is the gear ratio for the roamerdrive the same as a fairy o/d or is it different. Quote Link to comment Share on other sites More sharing options...
western Posted August 16, 2020 Share Posted August 16, 2020 25 minutes ago, Cornish Rattler said: Is the gear ratio for the roamerdrive the same as a fairy o/d or is it different. 28% difference Quote Link to comment Share on other sites More sharing options...
Peaklander Posted August 17, 2020 Share Posted August 17, 2020 The Roamerdrive is 28% and I think that the Fairy is the same. So no difference. Quote Link to comment Share on other sites More sharing options...
Cornish Rattler Posted August 17, 2020 Share Posted August 17, 2020 7 hours ago, Peaklander said: The Roamerdrive is 28% and I think that the Fairy is the same. So no difference. Are right ok, looking at swapping out the HRTC for a STD tranny box and fitting an o/d but keeping the 3.54 diffs but if I don't need the o/d well then I won't fit one. Quote Link to comment Share on other sites More sharing options...
Snagger Posted August 17, 2020 Share Posted August 17, 2020 14 hours ago, Peaklander said: Isn’t that what I said? Yes, but you said you “believe” they were a distributor, I was just confirming it in case you were uncertain. Quote Link to comment Share on other sites More sharing options...
Snagger Posted August 17, 2020 Share Posted August 17, 2020 7 hours ago, Peaklander said: The Roamerdrive is 28% and I think that the Fairy is the same. So no difference. Also correct. HRTC (for Cornish’ benefit) is 32% and 3.54 diffs give 35% (low range too, obviously, with a speedo calibration error to boot). HRTC and diffs will eventually break the gear box, Overdrive and diffs will be ok for the box as long as you only use the overdrive in fourth gear or in low range. Quote Link to comment Share on other sites More sharing options...
Cornish Rattler Posted August 18, 2020 Share Posted August 18, 2020 23 hours ago, Snagger said: Also correct. HRTC (for Cornish’ benefit) is 32% and 3.54 diffs give 35% (low range too, obviously, with a speedo calibration error to boot). HRTC and diffs will eventually break the gear box, Overdrive and diffs will be ok for the box as long as you only use the overdrive in fourth gear or in low range. Yeah I have already tried swapping back to a std diff but for town work it's still to high as 1st is like 1st with o/d even though I don't have o/d but at the mo 1st is like 2nd so I've lost 1st all together but 4th is really good for Mway as the rev's are right down and will do well over 90 but don't want to be doing them speeds really, would rather prefer getting 1st gear back and the cruising speed lowered Quote Link to comment Share on other sites More sharing options...
