FishBon Posted August 16, 2020 Share Posted August 16, 2020 Hi guys. Could somebody send VE and spark table maps The engine is from Discovery I and auto transmittion ZF V8 3.9 L (compression is 8,13:1) the injectors is deka 1d zmz 6354 it's defender build to sport (trophy TR-2) there are some pictures of manager and wire shema Now the engine start after 8-12 sec. and there is low power until 2800 rpm, yeasterday it's make 0-80km/h about 12,5 sec Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted August 16, 2020 Share Posted August 16, 2020 I don't know anything about the Secu-3, is it some sort of clone of the Megasquirt? Are you entering Ladoga TR-2? Please post a picture of your truck for us Quote Link to comment Share on other sites More sharing options...
FishBon Posted August 16, 2020 Author Share Posted August 16, 2020 Hi Fridge i think that Secu3t it's light clone of megasquirt U don't need to study it (sorry for bad english) I just need help to know that i use correct VE and Ignition maps or not for this engine (v8 efi 3.9 L) There is foto from Ladoga 2015 there is from Ladoga 2016 and here is video 15/08/2020 WhatsApp Video 2020-08-15 at 15.00.56.mp4 1 Quote Link to comment Share on other sites More sharing options...
FishBon Posted August 16, 2020 Author Share Posted August 16, 2020 also there is LOG's *.csv if it's help to https://yadi.sk/d/qhtkc_n4iqxT8A Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted August 16, 2020 Share Posted August 16, 2020 Do you run coil packs or keep the distributor? Is your fuel/spark map one that you know is for a Rover V8 or is it just some default map? It should not take 10 seconds to start, so you need to look at the reason for that - is it ignition pick-up, cranking fuel/advance, etc. There is a big thread by @Hybrid_From_Hell on here somewhere that takes you through the process of setting up a Megasquirt install. Quote Link to comment Share on other sites More sharing options...
FishBon Posted August 17, 2020 Author Share Posted August 17, 2020 Hi, there are coil packs (wasted spark) and ckp sensor (the wheel is 36-1) the spark and fuel maps i found in internet (i think that it should be for my motor? but i'm not sure) there are for 3.9 and for 4.0 V8 that i found Quote Link to comment Share on other sites More sharing options...
FishBon Posted August 17, 2020 Author Share Posted August 17, 2020 v8 4.0 Quote Link to comment Share on other sites More sharing options...
FishBon Posted August 17, 2020 Author Share Posted August 17, 2020 coil pack Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted August 17, 2020 Share Posted August 17, 2020 Has the car run OK before or is this a new install? If it's new - you need to make sure the timing is right (trigger wheel trim value), and as you seem to have changed injectors you will need to re-scale your REQ_FUEL value to account for the different flow rate. Quote Link to comment Share on other sites More sharing options...
FishBon Posted August 17, 2020 Author Share Posted August 17, 2020 Hi again before was CUX14 and distributor (motor work very poor and low power until 3500 rpm) the injectors is new and fuel pressure adjuster change to 3 bar the flow rate of injectors is 205 cc/min the upper dead center of 1 piston is on 8 tooth How can i rescale VE and ignition map for V8 3.9 ? Quote Link to comment Share on other sites More sharing options...
FishBon Posted August 17, 2020 Author Share Posted August 17, 2020 the injectors dead time for Deka 6354 there is Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted August 17, 2020 Share Posted August 17, 2020 You need to understand how the SYSTEM works - all we can do here is guess that it's mostly similar to megasquirt. Telling us where your crank sensor is doesn't help - you need to make sure that the values in the ECU are correct when the engine is running - if the ECU sets 10deg timing, does the engine show 10deg timing using a strobe light? A fuel map is only a table of corrections, it means nothing without the ECU knowing the engine & injector characteristics. If all of your ECU settings came from a SECU-3 install running on the same engine (3.9 V8) with the same injectors then it should be good (maybe not perfect, but certainly good). If you just picked up a fuel map without any of the settings to go with it then it's just guessing. The original 3.9 injectors are 191.8 cc/min so if yours are 205cc/min you would (on megasquirt) scale the REQ_FUEL value down to make the map "correct" again, there is a tool in the software that does this for you, or you can use maths If your engine has other problems causing it to run badly then you must fix those before you try to tune anything or you are just wasting time. You need to get the BASIC settings (ignition timing, base fuelling (REQ_FUEL)) correct before you try to change "fine tuning" things like injector dead-time - that stuff is the last 1% and you should not change 100 different things until the basic ones are good, it only causes confusion. Quote Link to comment Share on other sites More sharing options...
FishBon Posted August 21, 2020 Author Share Posted August 21, 2020 Hi again, what about original VE ang spark table map for V8 3,9 can i see it's somewhere? Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted August 21, 2020 Share Posted August 21, 2020 You did not answer the questions about checking the BASIC settings are correct, it is very hard to help you if you cannot confirm the basic steps first. The fact it is very hard to start and has no power suggests there is something more than just a poor fuel map - I believe the fuel & ignition maps are not used for starting... in megasquirt. Do you get no support from the manufacturer or any other users of the system? Because as it is a copy/clone of megasquirt we don't know 100% how it works, we can only assume it's similar to megasquirt but we could be completely wrong. Quote Link to comment Share on other sites More sharing options...
FishBon Posted August 27, 2020 Author Share Posted August 27, 2020 Hello again there is 2 degree btdc in manager on idling and strobo confirmed it'scon Quote Link to comment Share on other sites More sharing options...
FishBon Posted August 27, 2020 Author Share Posted August 27, 2020 now The engine start more better there is working VE and SPARK table maps WHat do U think Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted August 27, 2020 Share Posted August 27, 2020 I'm not an expert at tuning but there are some guides here; Especially the "Tuning" section: Tuning Nige's excellent tuning explanation And BBC's notes on the above. Narrowband VS Wideband Timing advance on an RV8 Discussion of a valley in the spark table Nige's tuning progress Nige's further tweaks etc... Quote Link to comment Share on other sites More sharing options...
FishBon Posted August 27, 2020 Author Share Posted August 27, 2020 thank's a lot i saw that page's yet 2 week ago Quote Link to comment Share on other sites More sharing options...
FishBon Posted February 14, 2022 Author Share Posted February 14, 2022 Hi every one again, now We replace V8 3.9 and mount V8 4.6 60D I need help to find injectors dead time (maybe it's bosch 0 280 155 778) Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted February 14, 2022 Share Posted February 14, 2022 I doubt it will make much difference, probably the default values or whatever worked with the 3.9 as the injectors on most 4.6's were the same as the 3.9 Quote Link to comment Share on other sites More sharing options...
mikeh501 Posted February 16, 2022 Share Posted February 16, 2022 on megasquirt a quick and dirty way of getting in the right ballpark (assuming everything said above) is to run the VE table tuning whilsst your driving the vehicle assuming you have a o2 sensor. It should put it into the right ball park... it not magic though and if there are just underlying issues it will mask them. Quote Link to comment Share on other sites More sharing options...
