Bbosa Posted August 23, 2020 Share Posted August 23, 2020 I just finished rebuilding a 200tdi defender 110 engine. It runs fairly good but the temp gauge indicates its extremely hot on climbing hills and stays close to red till you switch off the engine. How do I tell its actually the engine that is hot or the problem lies elsewhere? I suspect it could be either the belt, temp gauge, rad. How do I rule out the head gasket since I just put a new one on rebuild? Quote Link to comment Share on other sites More sharing options...
western Posted August 23, 2020 Share Posted August 23, 2020 Examine the radiator, the fins between the cooling rows just corrode away & the rad cannot dispose of the excess heat, you should have the 5/8unf PRC8593 temperature sender, is the thermostat the correct 88 degree item ? the new head gasket, which type was fitted the laminated steel type or the old style composite, I had a laminated gasket & it let the oil & coolant mix. Quote Link to comment Share on other sites More sharing options...
Bbosa Posted August 23, 2020 Author Share Posted August 23, 2020 20 minutes ago, western said: Examine the radiator, the fins between the cooling rows just corrode away & the rad cannot dispose of the excess heat, you should have the 5/8unf PRC8593 temperature sender, is the thermostat the correct 88 degree item ? the new head gasket, which type was fitted the laminated steel type or the old style composite, I had a laminated gasket & it let the oil & coolant mix. I will check on the above but how do I tell its the engine that is not hot or the vice versa? Quote Link to comment Share on other sites More sharing options...
western Posted August 23, 2020 Share Posted August 23, 2020 you can get temp sensing telltale stickers, you apply these to various engine ares/radiator & it'll either change colour or give a temp number of that part/area. https://www.google.com/search?rlz=1C1CHBF_en-GBGB911GB911&q=temperature+indicator+strips+uk&sa=X&ved=2ahUKEwjUkIaSirLrAhV6QUEAHbD1AxoQ1QIoAHoECAsQAQ&biw=1366&bih=633 or buy a heat sensing therometer https://www.amazon.co.uk/Infrared-Thermometers/b?ie=UTF8&node=6286456031 Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted August 23, 2020 Share Posted August 23, 2020 In addition to the above, did you replace the stat and if so is the new one a genuine one with a vent hole / jiggle pin in it to prevent airlocks? 1 Quote Link to comment Share on other sites More sharing options...
Bbosa Posted August 24, 2020 Author Share Posted August 24, 2020 5 hours ago, FridgeFreezer said: In addition to the above, did you replace the stat and if so is the new one a genuine one with a vent hole / jiggle pin in it to prevent airlocks? no I did not replace it and it was working properly prior to rebuild. I may have to check on the airlocks though. Quote Link to comment Share on other sites More sharing options...
Bbosa Posted August 24, 2020 Author Share Posted August 24, 2020 7 hours ago, western said: you can get temp sensing telltale stickers, you apply these to various engine ares/radiator & it'll either change colour or give a temp number of that part/area. https://www.google.com/search?rlz=1C1CHBF_en-GBGB911GB911&q=temperature+indicator+strips+uk&sa=X&ved=2ahUKEwjUkIaSirLrAhV6QUEAHbD1AxoQ1QIoAHoECAsQAQ&biw=1366&bih=633 or buy a heat sensing therometer https://www.amazon.co.uk/Infrared-Thermometers/b?ie=UTF8&node=6286456031 I will try a heat sensing thermo Quote Link to comment Share on other sites More sharing options...
Bbosa Posted August 24, 2020 Author Share Posted August 24, 2020 I have done some good work on the rad, actually it had some rusty parts at the bottom. i have also made sure the bleeding doesnt leave any air pockets especially around the stat. I also found the alternator belt worn out and replaced it. NOW the result is that the gauge settles slightly below the middle and it seems to be staying there even on hill climbing. Is this the normal position given that I have just rebuilt? Quote Link to comment Share on other sites More sharing options...
landroversforever Posted August 24, 2020 Share Posted August 24, 2020 Another question... is it the original engine to the car? Retrofitted 200tdi in an early car with the 200tdi temp sender will read hot when it’s not. Quote Link to comment Share on other sites More sharing options...
Bbosa Posted August 25, 2020 Author Share Posted August 25, 2020 6 hours ago, landroversforever said: Another question... is it the original engine to the car? Retrofitted 200tdi in an early car with the 200tdi temp sender will read hot when it’s not. It's a 200tdi engine fitted in a formerly 2.5 defender 110 1983 model. Quote Link to comment Share on other sites More sharing options...
Snagger Posted August 25, 2020 Share Posted August 25, 2020 5 hours ago, Bbosa said: It's a 200tdi engine fitted in a formerly 2.5 defender 110 1983 model. Then you really want to fit the gauge from a 200Tdi Defender to ensure compatibility. I wouldn’t replace the sender with a 2.5 unit as the engines may run normally at different temperatures, so a 12j indication system on a Tdi could give false indications, even though sender and gauge are matched. 1 Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted August 25, 2020 Share Posted August 25, 2020 ^ This, you need a matched gauge + sender, TBH I'd just fit a VDO Vision set and call it good. 2 Quote Link to comment Share on other sites More sharing options...
LR-USER Posted August 27, 2020 Share Posted August 27, 2020 When I put a disco 300i into my 90 defender , I had hot indication until we fitted the right sender for the defender gauge. problem was solved not sure of part number. a previous 200i 90 would sit at just below half and never budged. Nice engine, the 200. Quote Link to comment Share on other sites More sharing options...
