ianmayco68 Posted August 30, 2020 Share Posted August 30, 2020 HI all , I've brought a td6 l322 engine for a defender conversion and I'm trying to get the front diff out of the sump does anyone know how it comes apart ? I have searched but no joy , I've undone the bolts either side but can't part it any help would be great as next plan is a 9'' grinder . cheers Ian Quote Link to comment Share on other sites More sharing options...
steve200TDi Posted August 30, 2020 Share Posted August 30, 2020 Maybe a picture might help. Then you can add that in your build thread once we've helped you remove the diff! Steve Quote Link to comment Share on other sites More sharing options...
steve200TDi Posted August 30, 2020 Share Posted August 30, 2020 (edited) I have just found this from the Full Fat Range Rover forum: https://drive.google.com/file/d/0B5al230KXbSyckM0cERBcXZyY00/view From this thread: https://www.fullfatrr.com/forum/topic17623.html On page 329 it says quote 'The differential unit is secured to the engine sump with 4 bolts.' Have you removed the drive shafts? Steve P.S. More info here too: http://www.disco3.co.uk/forum/front-differential-repair-i-did-it-134360.html?highlight=Front+diff+removal Edited August 30, 2020 by steve200TDi Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted August 30, 2020 Author Share Posted August 30, 2020 Cheers Steve , build thread is Ian's 110 refresh been running a while only just started on this bit . Here's a couple of pics ,not brill ones and no drive shafts still in , I've removed the bolts from both sides diff moves freely in a circular motion , I was expecting to just be able to pry them apart when the bolts were removed, unless I'm not giving it enough umph . I'd already found the manual but couldn't find any reference to the BMW td6 engine only the tdv6 and the v8 . Quote Link to comment Share on other sites More sharing options...
steve200TDi Posted August 30, 2020 Share Posted August 30, 2020 Hmm, this may help: https://www.fullfatrr.com/forum/topic45172.html Sounds like there may be a circlip type arrangement and with a bit of for the diff and drive shaft can be forced apart allowing the clip to be pushed back into a groove and the two coming apart........maybe Steve Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted August 30, 2020 Author Share Posted August 30, 2020 Good find Steve , I think I did try that but with not enough force will try again tomorrow and post up how I get on . Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted August 31, 2020 Author Share Posted August 31, 2020 Nice one @steve200TDi 2 screw drivers between the ally housing and the cv and 30 seconds later out it popped , all the threads I found where going on about the Land Rover recall on the diff . So back over too the 110 thread now . cheers Ian Quote Link to comment Share on other sites More sharing options...
steve200TDi Posted September 6, 2020 Share Posted September 6, 2020 Excellent, glad you're sorted it! Steve Quote Link to comment Share on other sites More sharing options...
