RichardAllen39L Posted September 6, 2020 Share Posted September 6, 2020 Does anyone have experience of a good wheel/tyre package for a 2015 Evoque to do some moderate off-roading - ideally, something based on BF Goodrich All Terrains ? Quote Link to comment Share on other sites More sharing options...
steve b Posted September 6, 2020 Share Posted September 6, 2020 Welcome to LR4x4 , what size wheels and tyres are fitted now? Also can you expand a little on moderate off-roading as it will mean different things to different people , background and context will help with any suggestions . cheers Steve b Quote Link to comment Share on other sites More sharing options...
elbekko Posted September 6, 2020 Share Posted September 6, 2020 A friend of ours has some 32"ish Yokohama Geolandars on his FL2, which work very well. Can't remember the exact size he has. Quote Link to comment Share on other sites More sharing options...
Blanco Posted October 9, 2020 Share Posted October 9, 2020 Size is possibly the main issue, and you may need to consider another set of wheels? if you have 235/60 18's you may find your choice is limited to the all-weather road tyres anyway, changing to smaller wheels would help a lot but then you need to check clearance for brakes in the wheel. Putting taller tyres on your 18's will give you more choice again but then I don't know if Evoques have adjustable steering stops or at what point you run into clearance issues under the wheel arches, taller tyres obviously then affects speedo etc. on road. Use a tyre size comparison calculator on the web to check physical dimensions against each other and see how close you can get something. As a rule of thumb most cars will allow snow chains to be fitted and so a modest increase in tyre size overall is workable. Quote Link to comment Share on other sites More sharing options...
