Sorry to start on about d2key fob not working but I have read that much about this topic and totally confused myself.
So here goes the key fob hasn’t been used for a long time just used key in drivers door works every time the alarm doesn’t go off.
The other day mrs snapped key in door lock managed to get it out and use spare key. So now thought it was about time I sorted key fob out. New batteries in both fobs one only works when holding fob next to receiver in roof the other dose not work at all the red light on both fobs light up when buttons pressed
am I correct in thinking receiver faulty I have removed it and no sign of water or any damage non sun roof model year 2003 also any ideas why 2nd remote not working
thank you all advice appreciated as I don’t want to just guess and spend money when I don’t need to
i have no diagnostic equipment
Link to post
Hi Steve,
Has this other fob ever worked at all? Just thinking it may need programing to BCU. Did you make sure the receiver earth was clean?
If you put your aprox location in your profile there may be someone near you that could help.
Griff
Link to post
Hi griff thank you for reply I don’t know if the second fob ever worked, yes I checked the earth was clean as I said one fob works if you hold it next to the receiver I don’t mind paying for a new receiver just want confirmation if it is the receiver
Link to post
A new receiver is just plug & play - no programmimg needed. As mentioned above, if your put your area of the country in your profile someone near you with diagnostics can read if the key is programed to the vehicle.
Griff
Link to post
Hi just an update borrowed NanoCom plugged it in only one key code in bcu put second key no in unplugged NanoCom tried second fob no joy car still started everything still works apart from fob . First fob still works if you hold it next to receiver plugged NanoCom back in now won’t connect to Ecu any ideas
Link to post
