Ben-90 Posted September 15, 2020 Share Posted September 15, 2020 Hi. I’m struggling to find the problem with my td5 defender. Car runs but seams to be missing on 1 cylinder. White smoke out of the exhaust. It will cleared if revved hard but will go back to missing again. Changed air and fuel filter. Replaced injector harness (there was no oil leaking and top connector or in ecu). I’ve pugged a Hawkeye in and there is no codes apart from air-con but it’s not fitted. It did note that no.2 injector was slightly lower than others but only by 2-3. All injectors fire fine.Any ideas where I can look next. Thanks Ben Quote Link to comment Share on other sites More sharing options...
steve200TDi Posted September 16, 2020 Share Posted September 16, 2020 Lower by 2-3 what's? It could be your injector copper washers. I think white smoke refers to coolant loss, as blue smoke is oil and could relate to valve stem oil seals. Steve Quote Link to comment Share on other sites More sharing options...
Peaklander Posted September 16, 2020 Share Posted September 16, 2020 White smoke can be steam or unburnt diesel. If steam, it disappears quickly in the air whereas if it’s diesel the smell lingers. Quote Link to comment Share on other sites More sharing options...
