trickydicky 9 Posted September 17, 2020 Share Posted September 17, 2020 hi ive fitted a new 200tdi chassis loom and iv forgotten were the reverse wires plug in to .they are both green and i cant find the corresponding place for them . has anybody got any pics ? Quote Link to post Share on other sites
western 873 Posted September 17, 2020 Share Posted September 17, 2020 to the reverse light switch on gearbox one green/brown to reverse lights & one plain green from fuse box/12v power. on LT77 switch is at rear above Transfer box, if R380 switch is on the left side. Quote Link to post Share on other sites
trickydicky 9 Posted September 17, 2020 Author Share Posted September 17, 2020 lt77 to the bulkhead loom .everything else is fitted just the 2 wires (one male and one female ) Quote Link to post Share on other sites
western 873 Posted September 17, 2020 Share Posted September 17, 2020 I have a new chassis loom here, waiting to go in my 110, all the connections at forward end are pre moulded rubber single or multi plugs/sockets. so they should match up to the existing bulkhead loom. I can have a look at my bulkhead connections tomorrow & sort some photo's Quote Link to post Share on other sites
trickydicky 9 Posted September 17, 2020 Author Share Posted September 17, 2020 cheers western the loom fits well but when i removed the bulkhead i pulled out the plugs from the bulkhead including the one to the gearbox and its the only one i don't have a photo of and i cant for the life of me see were it goes 1 Quote Link to post Share on other sites
western 873 Posted September 18, 2020 Share Posted September 18, 2020 looked at my 110 the reverse light wiring is like this. reverse switch 2 wires. to a 2 core cable [2 x green/brown trace] from switch going forward then up bulkhead coming out adjacent to clutch pedal housing, 1 green/brown goes to the matching single green/brown that is within the chassis loom [single bullet connection] other green/brown goes to the rubber multi pin plug to connect to the plain green wire [12v feed from fusbox] photo's to follow. Quote Link to post Share on other sites
western 873 Posted September 18, 2020 Share Posted September 18, 2020 Quote Link to post Share on other sites
trickydicky 9 Posted September 18, 2020 Author Share Posted September 18, 2020 once again cheers western all sorted now thanks to you 1 Quote Link to post Share on other sites
western 873 Posted September 18, 2020 Share Posted September 18, 2020 That's good news. glad the photos helped. Quote Link to post Share on other sites
Snagger 880 Posted September 19, 2020 Share Posted September 19, 2020 Stock photos, Ralph? There are some brown steel bit there which could have been galvanised...😝 Quote Link to post Share on other sites
western 873 Posted September 19, 2020 Share Posted September 19, 2020 7 hours ago, Snagger said: Stock photos, Ralph? There are some brown steel bit there which could have been galvanised...😝 These were taken in reply to the original question. so not 'stock' photos. the brown bits on clutch pedal housing I don't think will cause me a problem, I probably won't bother replacing the brake & clutch pedal housings for galvanised items, both got wire brushed & painted when I did the driver side footwell a while ago. Quote Link to post Share on other sites
Rustyv8 2 Posted September 23, 2020 Share Posted September 23, 2020 I was follow this post as I had the exact same wiring question for reverse on my LT85.... But nowhere in the engine bay have I got the equivalent 2 wires (Green and Green/Brown) to connect the 2 gearbox wires to. I’ve only got 1 connector left free on the 8way block for the rear lights and that’s the black/blue for my diff lock switch (yet to be connected).... I just seem to be missing 2 connectors somewhere!! 🤯 Im more concerned about the Green (fused) one... as I can just run a separate cable back to the reverse light if needed for the other one. Are they different colors on the Military loom by any chance? Quote Link to post Share on other sites
western 873 Posted September 23, 2020 Share Posted September 23, 2020 The looms use the UK standard wiring colours, Military vehicles were LR's were not normally fitted with reverse lights, so they could not show white lights to the rear in a operational situation, so quite likely the 2 core wires & reverse light switch were never fitted when built. Quote Link to post Share on other sites
Rustyv8 2 Posted September 23, 2020 Share Posted September 23, 2020 Holy carp!! You learn something new every day. Must admit this did cross my mind... however my LT85 is a refurbished ex MoD box, and it had the wiring still attached to the gearbox so figured I was wrong 🙂 i assume it’s ok to find another power feed as long as it’s fused? (What amp rating is it normally?) Quote Link to post Share on other sites
western 873 Posted September 24, 2020 Share Posted September 24, 2020 On civvy vehicles the reverse & brake lights share a fuse, can't remember the rating. Quote Link to post Share on other sites
Rustyv8 2 Posted September 24, 2020 Share Posted September 24, 2020 Thanks Western, that helps... Quote Link to post Share on other sites
