McKenzie Posted September 20, 2020 Share Posted September 20, 2020 Good morning I am on this forum because no one in South Africa seem to find the problem: I stopped at a stop street, when I try to pull away, nothing happened. The car was just idling. No power going through to the diesel pump etc. I switched off and restarted , I could drive again, 1km she was low on revolutions, no real power. I could drive at 20km and hour otherwise she cuts out. She went to a Landover specialist, put on diagnostics. She registered the following problem PCM P167B. After sending the fuel injectors for a diagnostic, one fuel injector had a back leak. It was corrected, re-programmed and off she went, 5 km later the same thing happened. A new crank sensor replaced the old one, still nothing. It seems that no one can figure this out and people just ant to replace parts. I am using this vehicles to do my research in the Kalahari and cannot be stuck in the middle of nowhere. Has anybody had a problem with this or an help me to figure this out please? All help will be greatly appreciated thank you, Celeste Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted September 20, 2020 Share Posted September 20, 2020 (edited) Welcome to the forum If you look on defender2.net and search for 2.4 loss of power there are a few things identified that may be checked but it looks like main wiring harness had chaffed causing loss of signals regards Stephen Edited September 20, 2020 by Stellaghost Quote Link to comment Share on other sites More sharing options...
