200tdi overheating but no heating ??
Think it’s sorted Mo. Pretty sure it’s the gauge that’s faulty.
I did drain it all and re fill.
cold air through heaters was an embarrassing mistake. I had both switches (temp and direction) push upwards. “Cold” 😂 ... in my defence I hadn’t stuck the new sticker onto my raptor binnacle so was going by memory
As always I appreciate all input.
It’s because of the knowledge of members/owners, a vast majority of the time on this site that we are able to keep these great vehicles running .
well done all 👍🍺🍺
  • Haha 1
well done all 👍🍺🍺
The same mistake is easy to make in SIIIs too - the colour coding is on the lever knob itself, and rubs off quickly in use, so you lose all the labelling for temperature, direction, and even which lever is which!
  • Like 1
Glad I’m not the only one.
Sitting outside the range at the minute waiting for the wife who’s spending my hard earned on carp.
I’ve spotted a Halfords and thinking what do I need ???
All I can think of is antifreeze...
what antifreeze should I be putting back in and how much please
Ps .. please be quick before she returns 😂
thanks
  • Like 1
when its up & running nicely heated up on a drive you should be looking at a full warmed working temp between 88 to 95 degrees, the thermostat is a 88 degree one. around 88 if the temp gauge is a good match you should see the stat open at 88 & the temp will go up a bit,
  • 3 weeks later...
That would work, I may have one in my garage don't click buy it now just yet
PM your post address & I'll send this item but without the attached sender, I had the 300tdi green sender to drive my old temp gauge, then I swapped it out for the VDO temp gauge  sender as in my photo's above.
Edited by western
