New P38 Posted October 11, 2020 Share Posted October 11, 2020 Hi, I’ve just bought a P38 2.5 dt in a T 1999 plate. Everything working fine then fob wouldn’t work, I got new batteries but wouldn’t unlock with remote. I have tried to start and a message which has never appeared before came up saying ECA manual! (Note: the car has not air suspension it has springs). Also when I can start it as it says engine disabled push remote. I have been online to try to resolve but nothing is working. Can anyone help me? Quote Link to comment Share on other sites More sharing options...
elbekko Posted October 11, 2020 Share Posted October 11, 2020 Try resyncing the remote - lock/unlock the car with the key while pressing the appropriate buttons. EAS manual message is probably because someone butchered the car and took out the air suspension. Quote Link to comment Share on other sites More sharing options...
Blanco Posted October 11, 2020 Share Posted October 11, 2020 +1 for re-synching, that is a skill you will need from time to time, take care to follow the sequence exactly. Also check you have the EKA code for your car, it is the only solution sometimes. Many remotes display eratic behaviour with the receiver module, take care to get quite close to the vehicle, in some situations I have to put the key right up to the RH rear window for it to work. There is a known issue with the receiver and antenna which I suspect is part of my problem, but while it works I just go on using it. If you search for these problems you will find lots on here .... I also use Rangerover.pub, some very helpful and knowledgable guys on there. Quote Link to comment Share on other sites More sharing options...
New P38 Posted October 11, 2020 Author Share Posted October 11, 2020 Thanks Quote Link to comment Share on other sites More sharing options...
New P38 Posted October 11, 2020 Author Share Posted October 11, 2020 Tried re-syncing the key but no joy. Watched lots of videos online but nothing works. It is not asking for an EKA code but the radio does ask for a code but that’s probably due to a previous battery replacement Quote Link to comment Share on other sites More sharing options...
elbekko Posted October 12, 2020 Share Posted October 12, 2020 Yeah, radio code shouldn't be affecting starting. Do you actually see the little LED on the fob lighting up? Quote Link to comment Share on other sites More sharing options...
New P38 Posted October 12, 2020 Author Share Posted October 12, 2020 It’s all sorted now! I had knocked the engine cut off switch when cleaning the car. Quote Link to comment Share on other sites More sharing options...
Blanco Posted October 12, 2020 Share Posted October 12, 2020 Well, ... at least you learnt a bit about it in the meantime, ... every cloud, ... Quote Link to comment Share on other sites More sharing options...
New P38 Posted October 12, 2020 Author Share Posted October 12, 2020 Yes true, just glad it’s working Quote Link to comment Share on other sites More sharing options...
