david allberry Posted October 13, 2020 Share Posted October 13, 2020 The mudflap is fitted to a steel angle which is then bolted to the rear cross member with three bolts or rivets. How is this done? Any advice gratefully received. Quote Link to comment Share on other sites More sharing options...
western Posted October 13, 2020 Share Posted October 13, 2020 3 rivnuts in rear crossmember lower face, Video here on how to replace without special tools Quote Link to comment Share on other sites More sharing options...
david allberry Posted October 13, 2020 Author Share Posted October 13, 2020 Thank you very much. Good video for rivnut without special tool. It looks like the mudflap mount was fitted to the rear cross member with fat pop rivets. The holes in the cross member are 5mm; the holes in the mud flap mount are 7mm. So pop rivet would work with small bore washer. Quote Link to comment Share on other sites More sharing options...
western Posted October 13, 2020 Share Posted October 13, 2020 I would go with the rivnuts, M6 or M8 would be fine for mudflaps lots of antisieze grease on the bolt threads, but suitable rivets would work. Quote Link to comment Share on other sites More sharing options...
david allberry Posted October 13, 2020 Author Share Posted October 13, 2020 Great stuff; many thanks for the advice. 1 Quote Link to comment Share on other sites More sharing options...
