ianmayco68 Posted October 20, 2020 Share Posted October 20, 2020 Hi all , I need to buy a new rubber dump valve for the air filter canister NRC8955 , the rubber bit on the bottom with lips , but can't find one for less than £25 which I think is a bit excessive . So does anyone have a cheaper solution rather than a replacement ? cheers Ian Quote Link to comment Share on other sites More sharing options...
miketomcat Posted October 20, 2020 Share Posted October 20, 2020 Mine is bunged up because I have a snorkel so you could just bung it up. Mike 1 Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted October 20, 2020 Author Share Posted October 20, 2020 Cheers Mike , that's the kind of answer I like , FREE . I didn't know if it would affect the running of the engine bunging it up , but I'll definitely try it now . Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted October 20, 2020 Share Posted October 20, 2020 A length of old bicycle innertube would likely do just as well, but as Mike says blocking it off is fine as long as you check it for water once in a while. 1 Quote Link to comment Share on other sites More sharing options...
western Posted October 20, 2020 Share Posted October 20, 2020 Closing off the rubber drain won't affect the engine at all. Quote Link to comment Share on other sites More sharing options...
HampshireHog Posted October 20, 2020 Share Posted October 20, 2020 Ian , if you really want one ive got one knocking about still in good condition , your more than welcome to it free of charge Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted October 21, 2020 Author Share Posted October 21, 2020 That’s a very kind offer @HampshireHogthank you , but as there seems to be no reason it will cause problems I think I will block it off and see how it goes. Cheers all 👍. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted October 21, 2020 Share Posted October 21, 2020 IIRC we used to use a WD40 cap to seal off the drain when waterproofing as it was the same size. Mo 1 Quote Link to comment Share on other sites More sharing options...
Jon White Posted October 26, 2020 Share Posted October 26, 2020 I just welded a plate over mine Quote Link to comment Share on other sites More sharing options...
monkie Posted October 27, 2020 Share Posted October 27, 2020 8 hours ago, Jon White said: I just welded a plate over mine The hole is there to let water out, welding it up will obviously permanently prevent any water build up from escaping. Quote Link to comment Share on other sites More sharing options...
Jon White Posted October 29, 2020 Share Posted October 29, 2020 On 10/27/2020 at 6:42 AM, monkie said: The hole is there to let water out, welding it up will obviously permanently prevent any water build up from escaping. Not half as much water as it lets in when wading! Any water quickly evaporates in the warm airflow as the engine runs anyway..... 1 Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted November 29, 2020 Author Share Posted November 29, 2020 Came up with a solution , bought some large shrink tubing shrunk that on then folded it round and tie wrapped it , job done . cheers all Ian . Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted November 29, 2020 Share Posted November 29, 2020 Perhaps overkill, but my solution was to weld a bung in the bottom with a cheapy ball valve so I could drain any water out with a quick twist - a bit like HGV air tank drains. 2 Quote Link to comment Share on other sites More sharing options...
