92a Posted October 21, 2020 Share Posted October 21, 2020 Any one ? I have just managed to start a 1961 series 2 “Fire Armour” fire engine that’s been left outside for years it’s a 109 and has lost most of its fire engine bits and it shredded the fan belts , it’s petrol and has got a military style oil cooler and is 12v positive earth ? The belt that came off is 920 mm on the outside but the dynamo is as far out as it can go , Thanks Angus Quote Link to comment Share on other sites More sharing options...
David Sparkes Posted October 22, 2020 Share Posted October 22, 2020 I appreciate this doesn't match exactly with the information you have given. In the S2C forum there is a sub-forum to Workshop Wisdom called Service Data. Scrolling down will find: Fan/Dynamo/Alternator drive belt LR pn: 563132 or equivalent belt is 1050 by 10 mm For other engines (conversions) measure the path the belt takes in mm - Drive belts usually include the circumference in mm in the part number! You need to measure the inside circumference, NOT the outside. e.g. a 1050 belt will measure approx 1065mm around the outside circumference. You can also use the S2C Search facility, using the terms 'Fan Belt' and 'Show results as messages', but the 1050 measurement seems 'standard'. Regards Quote Link to comment Share on other sites More sharing options...
steve b Posted October 22, 2020 Share Posted October 22, 2020 I'd try a 920mm again as that old one will be worn etc. Local motor factors will often help out by giving you a couple of sizes to try and then return what you don't need . Vee-Belts are measured on the circumference around the outside by turning it inside out and stretching around the measuring gauge . What a great find , it looks like the original early exhaust manifold on there - what sort of recorded miles does it have ? Steve Quote Link to comment Share on other sites More sharing options...
92a Posted October 22, 2020 Author Share Posted October 22, 2020 I have had a good look through my pile of Land Rover books and found this in the Optional Equipment book , I searched for the pulley ( 530132) online and it’s for a dynamo the other 2 belt pulley ( 574870) is for models with an alternator , so I just need to find out how long 554389 belts are and I’ll be sorted ? Maybe? Angus Quote Link to comment Share on other sites More sharing options...
