boaterboy Posted October 31, 2020 Share Posted October 31, 2020 The subject warning light very occasionally flashes momentarily. The handbook talks about excessive amounts of water in the fuel. A new fuel filter was fitted about 13k miles ago. Is the warning light flashing a cause for concern? What can be done about it, ie could it be for reason(s) other than excessive water in the fuel? Any advice would be gratefully received. Quote Link to comment Share on other sites More sharing options...
western Posted October 31, 2020 Share Posted October 31, 2020 drain it via the plastic tap on the bottom, examine the wiring for any chaffing & rectify if there is any, squirt some moisture repellent into the electical plug & socket. Quote Link to comment Share on other sites More sharing options...
bear Posted November 1, 2020 Share Posted November 1, 2020 Thet did away with the sensor on later models. Griff Quote Link to comment Share on other sites More sharing options...
boaterboy Posted November 1, 2020 Author Share Posted November 1, 2020 Thank you western and bear for your speedy and helpful replies, very much appreciated. It sounds as if it's not a safety critical issue. 1 Quote Link to comment Share on other sites More sharing options...
Glue Posted November 1, 2020 Share Posted November 1, 2020 Mine flashes when road conditions are very wet (or I'm wading) and stops when it dries out again. I get used to ignoring it. Quote Link to comment Share on other sites More sharing options...
western Posted November 1, 2020 Share Posted November 1, 2020 putting some vaseline inside the plug/socket may help to keep the moisture out. Quote Link to comment Share on other sites More sharing options...
boaterboy Posted December 4, 2020 Author Share Posted December 4, 2020 Thank you Glue and Western for your added comments. In fact, the light has not flashed again over the last 6 weeks since I noticed it first. 1 Quote Link to comment Share on other sites More sharing options...
