As some of us love trains & Metro's......
Arjan
Train ran through the buffer stops, & momentum took it to that part of the station.  as you can see there is no track bed on the left hand side. going to be a interesting & big crane needed to recover that railcar.
https://www.dutchnews.nl/news/2020/11/whale-tail-sculpture-stops-rotterdam-metro-train-from-crashing-into-water/
Several things are going to be adressed :
- The driver (why didn't he / she stop in time ?
- the auto brake system (it was programmed to stop before the end of the line)
- The stopblock (obviously not having done what it was expected to do)
As this is in the centre of Spijkenisse, getting big cranes etc. there - and reaching over the water and hig up - will make for interesting operations.....
59 minutes ago, elbekko said:
Impressive. And the cranes to recover that will be even more impressive.
For sure! I’d love to see that.
This was for the lift of a 35T tank at work, lift radius of I reckon 20m?
450T rated crane, with aN extra 120T crane to put the floor pads down. Then it ended up with 140T of ballast on the back of it.
Yes.....
Some clever people will be busy doing since as they have to reach over the water about 20 mtrs - away from the crane - but also 10 mtrs. higher... And the ground is soft there...
Going to be interesting..
Glad the driver is OK - rest is just money..
  • Like 1
