Holyzeus Posted January 11, 2007 Share Posted January 11, 2007 what are the pros/cons of separate or over the drum solenoids? apart from putting the pack out of harms/waters way? Quote Link to comment Share on other sites More sharing options...
BogMonster Posted January 11, 2007 Share Posted January 11, 2007 Easier to fit big spotlights on an A bar over the winch if required Low line fitting may allow you to put it under the bumper as Land Rover do with the M8000 but the main one is keeping the clicky bits out of the poo as you say Quote Link to comment Share on other sites More sharing options...
Br00n1e Posted January 11, 2007 Share Posted January 11, 2007 and they are sealed where standard solenoid packs aren't. That's why I changed mine Quote Link to comment Share on other sites More sharing options...
western Posted January 11, 2007 Share Posted January 11, 2007 Solenoids seperated from the winch make fitting easier in a restricted space & allow you to put most of the electrical parts out of the weather/road grime/mud, & to prevent idle fingers fiddling with parts you want to keep secure. Quote Link to comment Share on other sites More sharing options...
