Chambo110 Posted November 8, 2020 Share Posted November 8, 2020 Fellas first of all apologies.. I have read numerous posts on here now but I have confused myself with too much info. I understand the gauge is a simple switched live, neg, and signal from W post of alternator. However, the gauge I’m looking at has a switch on back for 4,6 &8 cyl.. and mentions wiring into the coil.. presumably petrol Mine is a 200tdi,, does this mean I can’t use the gauge I would like to ?? Or is the a way of manipulating?? Ta Mark Quote Link to comment Share on other sites More sharing options...
mmgemini Posted November 8, 2020 Share Posted November 8, 2020 Looking at your comments you seem to have a petrol type rev counter. 1 Quote Link to comment Share on other sites More sharing options...
western Posted November 8, 2020 Share Posted November 8, 2020 If it has 3 slide switches on the back put 1 & 3 up & 2 down. sounds like you have a petrol rev counter. VDO Vision do a 0 to 6000rpm one that will work with a diesel. https://www.merlinmotorsport.co.uk/p/vdo-tacho-52mm-diameter-0-6000rpm-333015010 Quote Link to comment Share on other sites More sharing options...
Chambo110 Posted November 8, 2020 Author Share Posted November 8, 2020 Thanks for replies fellas just 1 switch on back Ralph, switch between 4,6,8 do need a different gauge then ? Quote Link to comment Share on other sites More sharing options...
Chambo110 Posted November 8, 2020 Author Share Posted November 8, 2020 Bloody hell !!! £130 plus vat ? Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted November 8, 2020 Share Posted November 8, 2020 Petrol rev counters get their signal from the coil, so 1 spark pulse equals 1/4, 1/6 or 1/8 of a rev. Diesels don't have that, so they use the AC from the alternator [W]indings which are 3-phase AC driven by a belt that's some weird ratio of the crank speed... so yeah, you need a different gauge, or a different engine 1 Quote Link to comment Share on other sites More sharing options...
Chambo110 Posted November 8, 2020 Author Share Posted November 8, 2020 To save my marriage I’ll go for the gauge. Although I do love a v8 🤔 thanks chaps Quote Link to comment Share on other sites More sharing options...
western Posted November 8, 2020 Share Posted November 8, 2020 2 hours ago, Chambo110 said: Thanks for replies fellas just 1 switch on back Ralph, switch between 4,6,8 do need a different gauge then ? Yes, t it being a different type 3 sliders on VDO gauge rear face & a trimmer screw on the side via a small hole. some options less than 120 quid on ebay https://www.ebay.co.uk/itm/VDO-Tachometer-12v-Rev-Counter/303709508358?hash=item46b67f5306:g:TBoAAOSwDQdfc6RA https://www.ebay.co.uk/itm/2-52mm-12V-Tachometer-Gauge-Diesel-Motor-Engine-0-6000RPM-Meter-Rev-Counter/401937582708?hash=item5d9558ca74:g:Kf8AAOSwG4Zdtslt https://www.ebay.co.uk/itm/2-52mm-Digital-Car-Tachometer-Gauge-Blue-LED-0-9999-RPM-Meter-Rev-Counter-12V/392280041555?hash=item5b55b66853:g:300AAOSwWKpcuEK0 Quote Link to comment Share on other sites More sharing options...
Chambo110 Posted November 9, 2020 Author Share Posted November 9, 2020 Great help Ralph thanks just ordered the middle one.. can’t stretch to vdo at the minute. much appreciated Quote Link to comment Share on other sites More sharing options...
western Posted November 9, 2020 Share Posted November 9, 2020 Your welcome, hope it works ok Quote Link to comment Share on other sites More sharing options...
