Falklandislander2003 Posted November 9, 2020 Share Posted November 9, 2020 Hey guys I've got a bit of a dilemma here Im fixing up the old 2.5 110 down here and i put a fresh battery in her yesterday turned the key and nothing was going to put a jump lead straight onto the starter solenoid but not sure if its similar to the 200 tdi suggestions? Quote Link to comment Share on other sites More sharing options...
western Posted November 9, 2020 Share Posted November 9, 2020 Same starter motor as the 200Tdi engine, check the small white/red trace cable is connected to the solenoid spade terminal nice & tightly. Quote Link to comment Share on other sites More sharing options...
monkie Posted November 9, 2020 Share Posted November 9, 2020 Check the trace cable from the starter relay as Western says. If that checks out fine run a jump lead from the negative battery terminal to the engine block to bypass the earth. If that works then you have a faulty earth from the battery negative terminal. Quote Link to comment Share on other sites More sharing options...
Falklandislander2003 Posted November 10, 2020 Author Share Posted November 10, 2020 21 hours ago, western said: Same starter motor as the 200Tdi engine, check the small white/red trace cable is connected to the solenoid spade terminal nice & tightly. good to know cheers man 1 Quote Link to comment Share on other sites More sharing options...
