Trouble is its also related to fuelling, so if yours is fuelled differently to Ralph then I dont think you can compare the wategate directly.
Personally I would look at rotating your boost pin in the pump to increase fuelling on boost. The deeper the conical part of the pin that points forward the more fuel you will add. Black smoke under boost is bad so back it off if that happens.
Link to post
24 minutes ago, western said:
I will have to look & take a measurement tomorrow.
this attached cropped from my engine rebuild thread.
Ah ok . I may have a few more turns to reach that
ill  check tomorrow
thank you
  • Like 1
Link to post
It needs more fuel chucking though it, so as Richard has said pull the diaphragm and move the cone so the steepest bit faces forwards.
Dont worry about EGTs yet, you wont overly affect them until you mess with the max filling screw on the back of the pump.
Link to post
Good point.. need to confirm boost gauge working properly and giving correct readings first
will do that in morning
cheers 👍
Link to post
I’ve not got the cone shaped pin anymore, I have steggys pin and spacer ring
I do panic about blowing things up.. it’s been sat on drive long enough while I repair and tart it up.. I really don’t wanna be rebuilding an engine. 😂
Link to post
Christ, you paid his prices!!!
If I was you, pull the diaphragm out, the plastic collar (mines in long term storage in the hedge out the front of the house) and then move the throttle lever to the full loud position and see if the little pin shoots out in the hole. If it does then something is amiss somewhere. If it doesnt, that's why it's not going as well as you would like.
Link to post
Ooops ? Was I robbed then ?
I took plastic spacer out and put in one of the lose mysterious safe places ??
I know the little pin your on about. I pulled diaphragm out a couple days ago. Then took throttle linkage off to see if the baby pin moved by hand .. it did
didnt think to try moving the throttle lever 🙈
if it moves by hand I’m assuming it WILL move with the lever ?? Yay or nay ?
Link to post
Have you got the old pin still? Try putting that back in with it facing the front of the vehicle so the fuel pins gets most travel. Then see how it goes. If it solves your issues to will know it is the boost pin setup is what you need to play around with and the preload of that.
Link to post
Jon .. eeerrr not sure.. I’ll check tomorrow
reb .. yep cut out facing forward
Link to post
In fact.. the little baby pin that rides on the boost pin must be working as when I removed diaphragm to check the baby pin was moving I can see a line in the smear of red grease that’s supplied with the boost pin
make sense ?
Link to post
2 minutes ago, reb78 said:
Weird. So your fuelling is already set to more than standard.
what was your boost when u started fiddling?
I done 1 full twist of the rod and went for drive gauge was showing 9 I think
done another 2 full twists test drive showed 10
2 more twists and still showing 10.
if I Rev and accelerate hard it may go to 11 for a split second
thats as far as I have gone coz I bottled it in case engine blew up 😂
Link to post
Chambo,
You need to be accelerating hard when you setting the max boost pressure as you are setting maximum boost. Most of the time driving you won't be anywhere near it.
Stop mucking (with an F ) about with the control arm and get yourself a valve! It is soooooo much easier to adjust.
Lastly in the nicest possible way, if you don't understand what you are doing then do some research. Understand what boost is and what it does and how the boost compensation system works THEN you can make informed decisions yourself on what adjustments to make rather than asking and hoping. It really is quite simple !
Good luck with it 👍
Mo
  • Like 2
Link to post
13 minutes ago, Mo Murphy said:
Chambo,
Good luck with it 👍
Mo
Mo
waiting for valve to arrive.
Played around with rod before your original input about the valve
It might be my wording,  I was accelerating hard. Got 2 about 2500rpm in 4th uphill albeit a very small incline, then floored it, Max boost each time was as mentioned 10. I just expected a little more from the rod adjustments
Cheers
Link to post
1 minute ago, Chambo110 said:
Mo
Cheers
Do it in third not fourth. You want max revs to test this under hard load.
Link to post
Good.
Understanding will help you achieve what you want from it.
The attached file is a very good explanation of what and how.
Hopefully you will find it useful.
Mo
Ps if you haven't done it already, take the circlip off the wastegate lever and check that the wastegate is free and closes fully. If it's open a bit you wont max your boost.
Tuning_Land_Rover_Tdi_engines_Rev_2.pdf
Link to post
Not at all. The other chap's come with free rust. Nick really does know his stuff
Something else to check.  It is possible for the boost pipe that runs to the diaphragm to suck up excess oil (if overfilled) and to dump it in the 'pot' under the diaphragm. It will give the same power issues as you are experiencing...
...it's also possible to get a blockage or accidental crimp in the pipe
Just work through the whole system - check nothing is seized or blocked, before you move anything else
Link to post
Can’t remember what I paid now to be honest
quality was very good though.
checked that pipe for kinks and blockages.. all seems good.
Manual boost control just arrived . Rod set back to original position. Gonna leave it til tomorrow now.. weather permitting.
spent today reading through mo’s link and watching numerous vids
cheers all
  • Like 1
Link to post
Boost controller fitted.
see what you mean Mo  .. how easy is that now.
rod set back to standard, FIP not touched. Boost now is 14psi at approx 3000rpm in 3rd flooring it up the best hill I could find on this snooker table I live on.
feels sooo much better.
thanks all for tips, pics and links
  • Like 2
Link to post
I have 1.3 bar. My experience is, that higher boost keeps the the EGT low, when the pump is adjusted
I really thought long, whether high boost can hurt. The weakest point is the intercooler. If he can stand it, no hurt.
Edited by Sigi_H
Link to post
What Sigi said, higher boost keeps the EGT lower. Nice big intercooler helps too.
Glad the boost controller has made it easier, Chambo.
How does it drive now ? You still have the fuel pin fitted ?
For others following, the mumby controller on ebay is of a suitably agricultural design to fit right in under a Defender bonnet 🤣🤣
Mo
Link to post
There is a balance though isn't there when you consider intake temps? My understanding is that if you increase boost too much and you compress the air more and therefore heat it more and lose the benefit of the extra boost?? A more efficient intercooler comes into play with this too then.
@Daan had some data on this IIRC as he had temperature gauges fitted on both sides of the intercooler.
Edited by reb78
Link to post
