200tdi Boost help
2 hours ago, Mo Murphy said:
What Sigi said, higher boost keeps the EGT lower. Nice big intercooler helps too.
Glad the boost controller has made it easier, Chambo.
How does it drive now ? You still have the fuel pin fitted ?
For others following, the mumby controller on ebay is of a suitably agricultural design to fit right in under a Defender bonnet 🤣🤣
Mo
Yep steggys pin still fitted. Goes well I think. Other than a little puff on start up I haven’t noticed any big black or white clouds behind me.
might have to get the wife out to observe though as when going forwards at speed I prefer to look the same direction
cheers
23 minutes ago, Sigi_H said:
It is said, that a decrease of intake temp of 5°C makes minus 50°C EGT. Don't know, if it's right, but plausible. Intercooling is important
Interesting - so if the intercooler cant cool more then the temp introduced by compressing then you may do more harm than good by increasing boost... I wonder where the sweet spot lies with the standard setup - i.e. is the 0.85 bar it for the factory 200tdi or was there a fair bit of leeway on that?
  • 10 months later...
On 11/12/2020 at 2:20 PM, Mo Murphy said:
Leave the rod length standard and use a manual boost controller to adjust your boost pressure.
Much easier to get at and simple to fit.
Shortening the rod is so last year.
Mo
Just came across this thread (missed it previously) and its very interesting! Where did you get this controller Mo? Are they engine-specific or one-size-fits-all? Seems like a more civilised way to adjust/manage boost than with the threaded rod which has an inherent desire to destroy your finger nails!
1 hour ago, Peaklander said:
Yes that’s the one I got and it was recommended by @Mo Murphy I think.
Mine is a 300 TDi and I fiddled until I got about 1.1 / 1.2 Bar and have left it alone since.
Grand stuff!
33 minutes ago, Mo Murphy said:
That's the one I use John, it's design is suitably agricultural to fit in with the 200tdi 😁
Mo
"Agricultural" sounds just perfect! Thanks for the confirmation. I think thats a really useful thing. And its NOT what I thought - some uselessly elaborate and complicated device - rather a very simple and elegant solution to a right old faff!
