ianmayco68 Posted November 15, 2020 Share Posted November 15, 2020 Hi all , is there any of you knowledgeable gentlemen with a milling machine looking for a small project in this lock down and would be willing to do me a favour ? Beer tokens for any one that can help , as to the job , I need a couple of vent openings making for the top of the dash to replace these , as I've custom made my vents . I don't want the shape to be as complicated as the originals , just made out of between 10 and 20mm aluminium bar with a slot milled in it which is wider than the original . If any kind soul can help I'll order a bit of bar and provide some sketches then sort out the logistics . I could drill each end then cut out with an angle grinder which is my last resort but milling would look a lot better . cheers Ian Quote Link to comment Share on other sites More sharing options...
western Posted November 15, 2020 Share Posted November 15, 2020 Ask Vulcan Bomber. 2 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted November 15, 2020 Share Posted November 15, 2020 I could help if your struggling for someone local regards Stephen 1 Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted November 15, 2020 Share Posted November 15, 2020 4 hours ago, ianmayco68 said: Hi all , is there any of you knowledgeable gentlemen with a milling machine looking for a small project in this lock down and would be willing to do me a favour ? Beer tokens for any one that can help , as to the job , I need a couple of vent openings making for the top of the dash to replace these , as I've custom made my vents . I don't want the shape to be as complicated as the originals , just made out of between 10 and 20mm aluminium bar with a slot milled in it which is wider than the original . If any kind soul can help I'll order a bit of bar and provide some sketches then sort out the logistics . I could drill each end then cut out with an angle grinder which is my last resort but milling would look a lot better . cheers Ian Yep! Drop me a PM. 2 Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted November 15, 2020 Author Share Posted November 15, 2020 Cheers Stephen , @vulcan bomberthank you very much PM on it's way . Quote Link to comment Share on other sites More sharing options...
