JACK WARNER Posted November 23, 2020 Share Posted November 23, 2020 Hi,i got a problem that is long lasting as for many V8 : Sometime to start the engine is a drama.I changed in the years 2 times the fuel pump and today i have fitted amr4956 in place of of the original box.I suspect that i have not solved the problem . A couple of time i have started the engine after a bypass from coil to battery.In the meantimei shoul change one of the chip of one of the keys.Should buy anyone or a relate to alarm box chip? tks jack Quote Link to comment Share on other sites More sharing options...
ballcock Posted November 29, 2020 Share Posted November 29, 2020 Hi Jack, and welcome to the forum. I would occasionally have a problem with my V8 starting and finally located the fault to a multi plug in the passenger footwell. The fuel pump wasn't getting any power. If when you turn the ignition on you don't hear the pump buzz for a few seconds it might be the same fault. water gets into the plug and causes poor contacts so pulling it apart and use a good electrical contact cleaner pushing the connectors in and out a few times. I hope you get to the bottom of it quickly, Tom 1 Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted November 29, 2020 Share Posted November 29, 2020 If it has a distributor + ignition amplifier it could be worth trying a spare/replacement amplifier module as they love to go bad with temperature. 1 Quote Link to comment Share on other sites More sharing options...
teabag Posted December 5, 2020 Share Posted December 5, 2020 (edited) On 11/23/2020 at 4:11 PM, JACK WARNER said: Hi,i got a problem that is long lasting as for many V8 : Sometime to start the engine is a drama.I changed in the years 2 times the fuel pump and today i have fitted amr4956 in place of of the original box.I suspect that i have not solved the problem . A couple of time i have started the engine after a bypass from coil to battery.In the meantimei shoul change one of the chip of one of the keys.Should buy anyone or a relate to alarm box chip? tks jack Hi, as you haven’t replied to the above suggestions can we assume that the issue with your vehicle has now been resolved ? Edited December 5, 2020 by teabag Quote Link to comment Share on other sites More sharing options...
