ThreePointFive Posted November 25, 2020 Share Posted November 25, 2020 1988 Land Rover 90 V8 I can't find the clevis pin/whatever it is that is meant to hold the lower heater control cable in place. This isn't shown on any of the normal diagrams. Also while I'm asking, there's a pin that holds the bonnet release cable on the mechanism that releases the cable itself - I also need that one. Any help greatly appreciated, thought these would be easy, apparently not. Quote Link to comment Share on other sites More sharing options...
David Sparkes Posted November 26, 2020 Share Posted November 26, 2020 I'm only answering because the questions have been 'ignored' for longer than I expected, but bear in mind I'm working off the diagrams; I don't have any knowledge of any Defender. I can't really tell from your photo, but when you say 'hold the lower heater control cable in place' I have interpreted that as the part clamped onto the cable inner AND engages with the lever, so the inner moves as the lever is moved. I suspect this is RTC5978. The link goes to the page on Land Rover Workshop; if you scroll down you will see diagrams from the parts manual. Click on the diagram to expand the view; the item is highlighted in this view. If you are looking for the clip that holds the cable outer in place, this is 'Clip retaining 13H7343L', another link to the LRW site. Moving to the 'pin that holds the bonnet release cable on the mechanism that releases the cable catch itself ', I was thinking it might be another RTC5978, but it isn't! This MIGHT be Retainer Cable 356225 (now STC926) No picture on LRW, but there is one on Craddocks under that number. This also requires Bolt 257194, but LRW don't list it as such, cross referring you again to STC926 Using STC926 we see it is a 'kit' comprising both the trunnion and the bolt (STC927 is the Metric version). While Craddocks have a picture, so do Paddocks, at much less money. I suspect it all depends on postage, and what other parts you order at the same time. Checking back, I see that Paddocks also stock the RTC5978 and 13H7343L. Regards. 1 Quote Link to comment Share on other sites More sharing options...
ThreePointFive Posted November 26, 2020 Author Share Posted November 26, 2020 David, really appreciate you taking time for such a comprehensive response. You've identified the part numbers I suspected but wasn't sure, which makes me confident enough to order. £10 for what is essentially a nut and bolt is steep, but given it's a very specific nut and bolt that I can't make myself, thre's no option. Thanks again for the help and looking forward to seeing if we're right... Quote Link to comment Share on other sites More sharing options...
western Posted November 26, 2020 Share Posted November 26, 2020 hopefully you can see the trunnion & clip in this extract from a photo of my heater unit, side cable & top cable both cables use the RTC5978 & green spring clips that David has linked to. Quote Link to comment Share on other sites More sharing options...
western Posted November 26, 2020 Share Posted November 26, 2020 The bonnet cable outer sleeve has to be fitted to this https://www.lrworkshop.com/parts/13H489L spring clip then it clips into the rectangular hole on the slam panel, just to the left [as you look at it] of the trunnion fitting for the inner cable, Quote Link to comment Share on other sites More sharing options...
